16-06-2013, 07:26 PM | #271 | ||
Lacking Imagination
-Bled the brakes
-Bled Master Cylinder -Played with QuarterHorse -reassembled Interior -degreased engine bay -fixed restriction in Transmission lines
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
20-06-2013, 06:48 PM | #272 | ||
Super Happy Fun Slide
The adjustable 30mm front and 22mm rear Whiteline sway bars that I got on Fleabay arrived today
Fitted them up to the XR6 straight away, set them on the softest settings to start with, over the next week or so I will attempt to dial them in for optimal handling. Im sure that trying to get a 1800kg boat to sit flat with the desired handling characteristics I'm after whilst still using the standard compliant shocks (new) and springs and using 235/40 17 Bridgestone MY-02 tyres will be a frustrating adventure |
20-06-2013, 08:06 PM | #273 | ||
Didn't do nothin' to it ... it's in the panel beaters.
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better! |
20-06-2013, 08:13 PM | #274 | ||
Started to repair the rear beaver panel.
It's nearly $400 for a new replica and I've got better things to spend my money on. I tapped it out pretty well, paint stripped it, welded up a couple of holes and beat it some more then etched it. Tomorrow I'll put a skim of bog in a few places and see how it comes up. |
20-06-2013, 10:35 PM | #275 | ||
Today I fitted a new radiator to my Territory. the old one developed a pinhole sized leak right at the top in the centre after 220,000 km. Quite an easy job apart from the two ten mm bolts at the bottom which take about 15 mins each after removing about a dozen small bolts that hold the plastic cover below the radiator. Not cheap though, $290 for the radiator, $100 for the five hoses, $20 for a new cap, and $40 for new coolant
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
25-06-2013, 05:15 PM | #276 | ||
Fitted a lower grill to my BF XR 6 I got on flea bay.
It has the exact same style and design as the top grill. Excellent bit of kit with a perfect fit for only $80. It really tidys up the front end, Ford should have had one standard, cheap buggers. |
25-06-2013, 05:25 PM | #277 | ||
First rinsed XR6T with water then washed her & then to waxed her
Proud owner of: 1970 Fairmont XW (waiting for restoration) & my daily Venom red 2003 BA XR6T Nick. |
25-06-2013, 06:18 PM | #278 | ||
BF XR8 Ute
New plugs,new Accsel coils.Fitted led brake and indicator lights to sports bar on my ute.
25-06-2013, 09:08 PM | #280 | ||
Unlocked the door....started the engine....drove it to the supermarket and parked it....bought milk went back to car....opened door....started engine again....drove it home and garaged it again. 'oh whata feeling, oops....wrong add!
26-06-2013, 12:20 AM | #281 | ||
Sunny side up
put $30 of fuel in it. car feels more responsive and gear changes are much smoother. best mod ive done so far
-= BF MK2.5 XR6 =- Genies>hi-flow cat>X-Force 2.5" Catback. Stage 2 crow cams. Powerbond 20% Underdrives. Bent tab. BC racing Coilovers. Whiteline Adjustable Swaybars. SS Inductions Growler + XR8 snorkel + Territory intake pipe. More to come. Thread coming soon. [P]Plater Past rides: 1998 NL Ghia Concorde (Now Dads car) 1954 Austin A40 |
26-06-2013, 12:52 AM | #282 | |||
Sent from my HTC Aria using Tapatalk II.IV.X
Before - ED Falcon Futura (sold) EL XR6 (R.I.P.) VX SS (R.I.P) VE Berlina |
26-06-2013, 12:54 AM | #283 | ||
Lacking Imagination
Fixed my Throttle Cable throw, Helping my engine to achieve WOT,
this has helped the engine perform better, and help me out pace a WRX and Grange on the Freeway this evening!
26-06-2013, 02:15 AM | #284 | ||
Started it and drove it, filled it up with petrol - this is after spending the weekend ripping the LPG system out of the explorer an converting back to petrol (installed petrol tank, fuel rail, injectors etc). Pretty satisfying really.....
26-06-2013, 03:55 AM | #285 | ||
Did oil and oil filter change...
_______________________________________________
Out with the old: 2006 BF XR8 Falcon - 240RWKW Difilippo Headers, Magnaflow 200CPSI Cats, X-Force Quad Stainless Exhaust, BPR CAI, ZF 6 SPD, Tuned by CV Performance! In with the new: 2009 FG XR6 Turbo Falcon - Stock as a rock (but not for long) EGO Colour with premium audio and ZF 6 SPD |
29-06-2013, 10:32 AM | #286 | ||
XF Owner
Put my left side window back on the rails hahahah Woo Windows
29-06-2013, 10:49 AM | #287 | ||
Installed a truetrac on Wednesday into the ute, Today had the dump pipe fixed after it cracked for the second time, waiting for the call to go and pick it up with the new xforce dump pipe that hopefully isnt going to crack again. One good thing is that Xforce are warranting their work and paying for labour and the replacement parts.
29-06-2013, 02:50 PM | #289 | |||
Cane Farmer
I missed 2nd gear.
1994 ED XR6T - Cobalt Blue. 2009 FG XR6 - Black. Quote:
29-06-2013, 03:23 PM | #290 | ||
Changed the fuel filter and had the auto oil changed on thursday, and it looks like the thermostat needs to be done...
29-06-2013, 04:03 PM | #291 | ||
car is nearly 3 years old .... factory battery died ... new Supercharge MF50 600CCA battery fitted ($130 inc. fitting disposal of old battery)
29-06-2013, 04:56 PM | #292 | ||
R51 Pathy, 91 Jayco Swan
Color sanded and re cleared xr6t boot. Polished faded brembo calipers on the GT.
29-06-2013, 05:21 PM | #293 | |||
29-06-2013, 06:22 PM | #294 | ||
Installed new boot struts and applied some rust converter to some spots in the corners of the boot near where the struts attach. I just got the car two weeks ago(AU Fairmont) with hardly anything wrong with it but the boot leaks and there is the tiniest bit of rust starting to show in there. Should be an easy fix and I won't stop till it keeps bone dry. A leaky car is a disaster waiting to happen if neglected. Oh and replaced tail light loom as the brake light socket was broken.
29-06-2013, 06:25 PM | #295 | ||
Went to Fibresports and got new GT rear bumper, mercury silver rear insert, GT side skirts and black GT rear spoiler fitted.
Will show pics tomorrow. |
29-06-2013, 06:26 PM | #296 | ||
Lacking Imagination
Went to the exhaust shop this morning to finally track down this little leak / rattle.
turns out i have blown both of the cat honeycombs back within the cats, which is causing them to rattle.
29-06-2013, 06:54 PM | #297 | ||
I bought a digital music interface for our Peugeot and it arrived in the mail yesterday. Installed it last night and now our 307 has iPod connectivity, USB and aux, Bluetooth hands free phone and streaming. All controlled through the steering wheel controls too. All for $125 from eBay!
Sent from my Galaxy Nexus using Tapatalk 4 Beta
Cheers, Sam. |
01-07-2013, 01:12 PM | #298 | ||
tried to fix my ipood cable. Falling to bits :(
01-07-2013, 01:12 PM | #299 | ||
also bought a set of staggered 19s Icon Zest
01-07-2013, 01:16 PM | #300 | ||
Parts Interpreter
Missed 2nd and then hit the throttle... Out the front of work
Gonna cop it tomorrow.
BFMKII XR6 Turbo Sedan
6sp Manual Pedders Coilovers Short Throw Shifter |
3 users like this post: |
