29-02-2008, 07:15 PM | #31 | ||
You can't stop the signal
I've just rerun those calculation for the M90 and come up around the 10psi too.
And i was just about to say the same, for a stock motor, 10psi is more than enough. And adding to that, 10psi from a PD blower will be a better 10psi from a turbo. If people are going to go second hand M90's i would just be warned about the wear that they have. A worn roots blower will produce alot of heat which is not from a performance aspect or a detonation aspect either. But for the price, if you could do the fabrication work yourself and the install as well, you could probably do it for under $3000, with a new blower. But that will have no engineering certificate or be road legal, so to speak. But since when did that stop us : :eclipsee_ Cheers |
29-02-2008, 09:10 PM | #32 | |||
With getting 20psi from a Wipple, I have no doubts it would produce this, but you would need $20k just to get started with costs of an engine, tranny, diff and so on. Would a car even be drivable with 20psi of boost at less then 2000rpm? Just because the blower can do it doesn't mean it has to. |
29-02-2008, 09:16 PM | #33 | |||
www.TUFFCARPARTS.com
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
29-02-2008, 09:23 PM | #34 | |||
Sly like a G6
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
29-02-2008, 09:31 PM | #35 | ||||
As for driveability, that is the beauty of the whipple and the M90, they produce boost right from idle, they always make power. They are well suited to "doughy" engines, that lack power down low, such as a low compression motor, in need of boost Another benefit of these kinds of blowers is that boost can be changed in about 5 minutes, simply by changing the blower pully. You can undrive them massivley and they won't complain. They will run 5psi, as easily as they will run 10psi or 15psi or more Another interesting point with kev's ute, if he drives it sensible it uses less petrol than what it did from the factory. He puts this down to the blower and the fact that he doesn't have to lean on the car as hard to get it do what he wants. But stand on the throttle and watch the petrol guage drop. The only driveability he has lost is grip. ====================:eclipsee_ Cheers
29-02-2008, 09:39 PM | #36 | ||
Grip is what I was talking about, I can't see you having any running 20psi
29-02-2008, 09:42 PM | #37 | |||
29-02-2008, 10:19 PM | #38 | ||
hahaha...
hrmm.. i might have to talk to my fabricator mate tomorrow night... ask him how hard it is to make up a manifold for one of these things... if he says he could try it... i might have to source an M90 and see how i go |
29-02-2008, 10:25 PM | #39 | |||
Sly like a G6
29-02-2008, 10:28 PM | #40 | ||
tho i have a question... what is the difference between these 2 eaton units...
one is labeled an M90.. the other as just a 90... are they the same thing?.. if so.. why is one longer with extra stuff on it?.. (i know nothing about PD superchargers) http://cgi.ebay.com.au/Ford-M90-Eato...QQcmdZViewItem http://cgi.ebay.com.au/eaton-90-supe...QQcmdZViewItem |
29-02-2008, 10:42 PM | #41 | |||
Sly like a G6
There's a bloke here in Newy who reckons he could fab up something for me if I gave him the car for 3 days. If he worked on it full-time for 3 days it'd be maybe $2K labour (GST included) plus materials????
29-02-2008, 10:51 PM | #42 | |||
Sly like a G6
29-02-2008, 11:00 PM | #43 | ||
hrmm.. ta...
i'll have to have a good chat with my mate tomorrow.. he knows a thing of 50 about boost.. heh.. he's built an 11 second sigma.. plus now an old school lancer but i think he's yet to run it.. which is all the motor etc from the sigma... |
29-02-2008, 11:07 PM | #44 | ||
Sly like a G6
Not the Sigma with the supercharged Commy V6?
29-02-2008, 11:19 PM | #45 | ||
nah nah... he used a standard 2.6 astron II motor... bolted a turbo onto it.. upgraded pistons.. then melted them at 19psi.. so did a full strip and rebuild... beefed up everything.. using a GT35/40.. running around 26 psi ... making a touch under 400hp at the wheels...
01-03-2008, 09:05 AM | #46 | ||
Sly like a G6
Noice. I have a '87 Courier fourbie which has an astron II... Mazda bought a batch to use while developing their 12V EFI 2.6... 8.2:1 compression... it'd be massively improved by the addition of 6 or so psi and I think the manifold from the Sigma Turbo would bolt on. Back in the day they used to decompress down to low-mid 7's and had massive lag. With advances in technology since then a low-blow turbo would be very nice on the stock compression, especially running LPG. I might do it if my plans for the Falcon keep getting frustrated.
It's something I could pull apart and take the time to play around with myself as I don't drive it that often. I don't have that luxury with the Falcon unfortunately, anything I put on it has to be fully-developed to bolt on and go in 2 days or less.
03-03-2008, 09:31 PM | #47 | ||
I saw an 88 extra Cab Courier 4x4 in traffic in Bris yesterday, was running the 2.6 EFI engine and one hella turbo, peeled rubber for the first three gears and the rubber was those 10R15s 4WD tyres. I was aghast at how quick this thing picked up speed, I think a 13 second quarter would have a real possibility.
Raptor VL & VLB (Billet compressor wheel) |
03-03-2008, 09:39 PM | #48 | ||
was it white??
ive seen that at harrys diner before was pretty tidy in the engine bay! theres also a few 4x4 hilux's with supra motors in them that peel big 4x4 tyres like they are 13" cheese cutters!
