03-04-2010, 06:20 PM | #31 | ||
Probably related to sub zero environments, something LPG has always has trouble with.
03-04-2010, 07:36 PM | #32 | ||
With Liquid LPG, the opposite is true about temperatures. The systems work great in the cold as they do not require coolant to expand the fuel prior to metering into the engine. In hot temperatures, people have reported slow refuelling times and lower than expected usable tank capacity. There's also the issue of purging the system to eliminate vapour 'bubbles' forming in the system prior to the injectors.
PoweredByCNG: Sick and tired of all the ignorant 'gas is crap' comments out there. |
03-04-2010, 07:40 PM | #33 | |||
Peter Car
03-04-2010, 07:46 PM | #34 | |||
Peter Car
They are in unchartered territory. Better off getting any potential reliability problems sorted now rather than later on when they could end up with a stack of warranty claims. Same thing happened with the BA E Gas motors that had to have the stronger rods fitted to prevent them bending after a backfire, something that happened quite a bit in early testing. Maybe this time they did not have the luxury of time to fix whatever problems they may have because it was only picked up late in the program. |
03-04-2010, 08:20 PM | #35 | |||
03-04-2010, 09:09 PM | #36 | ||
Peter Car
In terms of particle emissions then yes, but in other forms no. You can't say an engine that uses something like 1.3 L of petrol less per 100 km than a previous engine would be harder to get emissions compliant, it just requires a bit of extra work to make sure particle emissions are ok. Its simple science that for every extra litre of petrol you burn you get a corresponding increase in emissions out the tailpipe. And GM have already done the R&D on SIDI considering its already used both the 3.0 and 3.6 DI engines in the US. Wouldn't have been too hard for Holden to get it to pass Euro 4 as the engine was designed in the US to surpass those levels already, something the old 3.6 doesn't have.
I'd say its a simple case for Holden of not selling enough of them to justify getting it Euro 4 compliant, considering its the only model that uses the old 3.6. Just like the Territory Turbo come July. |
03-04-2010, 09:21 PM | #37 | ||||
something to do with corporate engine and US Tier 2 Bin 5 Emission for petrol already being tougher than Europe's standards... Here you go from Holden themselves in October 2008: Quote:
03-04-2010, 10:16 PM | #38 | |||
Fuel consumption only has a direct correlation with CARBON DIOXIDE emissions and that's it. Leaner air/fuel mixtures (i.e. excess of air), as used in direct injection engines, result in a significant increase in Nitrogen Oxide (NOx) emissions compared to engines running at stoichiometry. Since three-way catalytic converters are only efficient at neutralising NOx when there is no oxygen present in the exhaust stream, it is much more difficult to make a 'lean-burn' engine comply with NOx limits. The other issue with lean operation is that hydrocarbon (HC - unburned fuel) emissions are higher because the engine runs close to misfire. HC emissions are reliant on the state of the ignition system and catalytic treatment.
03-04-2010, 10:30 PM | #39 | |||
trying to get a leg over
Cameron ------------------------------------------------------ |
03-04-2010, 10:31 PM | #40 | |||
03-04-2010, 10:44 PM | #41 | ||
Could it be that Ford is trying to bundle production line changes to suit itself?
Thinking the new Territory arrives then, I thought about the possibilities: - eliminate all 4-speed autos from Falcon/Terry at one time - change over all LPG and trans package at same time - possibly drop BF 4.0 and make FG engine common across range? I remember Burela said something in an article last year about bundling changes... Government looking to bring forward Euro 5 and 6, maybe they triggered this? |
04-04-2010, 06:43 PM | #42 | |||
It happens overseas, but the cars that doe it have nox convertors in the exhaust systems, sort of like a cat convertor to eliminate the excess nox. The nox convertors will not work on our cars because of the sulphur content in our fuel, this sulphur will stop the nox convertor operating. The gov has not stood up to the fuel companies and demand change at this point of time. If the sulphur was reduced we could start to get proper lean burn engines.
04-04-2010, 07:39 PM | #43 | ||
I has less to do with lean/rich and more to do with droplet size, high pressure direct injection
is able to spray much finer mist with smaller droplet size for better mixing. The result is more power and better fuel economy depending on how the engine is tuned. |
04-04-2010, 07:53 PM | #44 | ||
Apparently oil sludging is becoming a big problem with DI engines, as the fuel is injected directly into the cylinders, it isnt washing the oil residue from the back of the intake valves.
04-04-2010, 08:55 PM | #45 | ||
Rob
the LI lpg engine isn't direct injection.
as mentioned earlier, what ford are doing different to the aftermarket is making a dedicated (single fuel) liquid injection system. from what i gather from snippets of info from blownba and others, there are rules relating to 'purging' of the lines with engine not running?? obviously this is why the dual fuel applications start on petrol and flick over to lpg at a set point. putting 2 and 2 together, personally i think the delay is something to do with this. |
05-04-2010, 10:34 PM | #46 | ||
Regulator
Anyone know if the LPi systems will be across the range or only G6 - XR6?
Shame about the delay!
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
