Old 20-05-2016, 09:31 PM   #31
4RDXR
Talking Re: rough idle and running rich
IDLE MoToR AnD fuel pressure regulator change
4RDXR is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2016, 10:00 PM   #32
gp351
Papa Smurf
Default Re: rough idle and running rich
so I guess the idle motor is part of the throttle body, can it be replaced seperately or complet throttle body? car is fine on highway, and pulls hard so seems to get plenty of fuel / pressure.
gp351 is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2016, 12:43 AM   #33
4RDXR
You can just buy the idle motor sits on top of throttle body
Ford still sell them around $220 or just get second hand one she'll run smother
Clean it out with carby cleaner BUT DONT spray towards the motor (the cylinder )
If the revs fluctuate when idling or when coming to a stop and has rough idle BUT doesn't fluctuate while accelerating
It's the IDLE MOTOR ......... You won't get any codes for this
Old 21-05-2016, 12:48 AM   #34
4RDXR
OH you also get **** fuel economy
Old 21-05-2016, 12:53 AM   #35
4RDXR
Change the fuel pressure regulator anyway
It's might have never been changed
You'll always get good fuel pressure on highway CAUSE theirs more suction from the engine which will compensate for a dirty regulator
Old 21-05-2016, 01:02 AM   #36
4RDXR
After you've done all that clear all codes
Supercheap auto can do it now for $20
Then while your still at supercheap auto reset ecu you don't need to disconnect batt just pull out the fuse for the ecu 10min and stick back in and reset like midgetyone said
Old 21-05-2016, 01:02 AM   #37
4RDXR
Now you owe me a case of Canadian dry
Old 21-05-2016, 10:20 AM   #38
gp351
Papa Smurf
thanks for all that.
