13-06-2016, 08:57 AM | #31 | ||
Yes that would make sense. Is valve body disassembly required to remove the screens?
I might give the local auto trans shop a ring on Tuesday as well.
2003 BA XR6 N/A SEDAN IN ACID RUSH CURRENT MODS: PACEMAKER 4490's, 3 INCH HIGH FLOW CAT, F6 CAI, K&N PANEL FILTER FUTURE MODS: CAT BACK EXHAUST, MAG WHEELS |
13-06-2016, 12:42 PM | #32 | ||
natedogg1986,
As you have already worked out, two of the originals used as S1 & S2 had filters and others did not. Replacement ones are all Bosch P/N - 0 260 120 029 with filters. The other number on the solenoid body is 0593-640076. They are suppose to have better O ring seals and filters. I replaced mine last year, all five of them and S5. Regards, George V |
13-06-2016, 01:14 PM | #33 | ||
So when replacing the ones without the mesh filter as part of the solenoid, is there a filter in the valve body that needs to be removed before install?
13-06-2016, 02:04 PM | #34 | ||
Did not see any filters in valve body.
Regards, George V |
13-06-2016, 08:32 PM | #35 | ||
No filters in valvebody
