#31 | ||
Adapt or perish...
Just got an e-mail back from my local dealer (Pacific Ford Maroochydore)
They tell me the part numbers don't even come up... EDIT - I put both those part numbers in the database, and they came up. I think I'll contact Ocean Ford in Noosa.
Carless
#32 | ||
Drought Breaker
I have a spare pair of those for anyone interested $13 ea + postage.
And I can also get the obsolete ones too if many are interested they are getting rare though. Could also be worth looking at the BA ones but I think they may be different because of the dash shape. Tim
2002 AUIII XL W/- Custom Tray
ALL COUNTRY: SW Platt Mccann 5 Poster, GME 4706 7' Whippys, Uniden UH015SX UHF AND Scanner combo, Narva Taurus Bull lights, Hawk Grille, Series II Pursuit Side Skirts, Stickers on the back window and more eartags than a mob of cranky angus ![]() ALL GO: XR6 VCT donk and ECU NO MORE!! Now even MORE fun with 200kw XR8 and 5 speed, Tickford Cluster, 3.45 LSD, full custom twin system w/- 3" chrome angle cut tips ![]() |
#33 | ||
surley FTG would have the parts??
but that is definatly bloody rediculous thing to do!! having only 1 side .. maybe they make a stockpile and wen its all gone.. thats it aye..
#34 | ||
Irregular Member
The local guy did mention the BA ones but he said the screens are different so they probably wouldnt fit.
Hey does anyone know what this piece of hard yellow foamy thing is for? Reduce noise or add support to the door trim? Either way did anyone remove theirs? |
#35 | ||
Adapt or perish...
Just got another reply from Pacific Ford Maroochydore.
They stuffed up (Surprise, surprise) ER F03513 B1 is $19.36 I gave them a wrong part number too. So I'll take half the blame. EDIT - ER F03512 B1 is no longer available.
Carless
#36 | ||
stevenau2 mine never had that.. but its a fairlane so *shrugs*
#37 | ||
Irregular Member
Finally worked out where to put that box thingy.I cut part of the ghard foam section out and the box fits nicely in the gap and doesnt stop the door trim going back on.Yes i realise i cut too much away but i was in a hurry.
#38 | ||
box thingy = crossover = what makes each speaker put out XYZ frequencys
looks like it was made for it (the hole you cut/placment of the crossover) has anybody got more pics of 6.5" splits installed with spacers in the 5x7 holes without the trim on as from what i could see the spacer had to be about 15mm thick to house my woofer and was wider than the 5x7 speaker it self.. so didnt know if the trim would fit back up etc with it on (and without screwing it all together i couldnt place the trim on to see if it did fit/clear) and having the grille on the door i could not see how much clearance the speaker had thanks for the info so far guys!
#39 | ||
Irregular Member
Ok guys i finally got my speakers in,the only thing showing that they arent stock is the tweeter.
Ive attached afew pics for future guys. 1-10mm mdf painted black so you cant see thru speaker grille,made a template out of cardboard then traced onto the mdf. 2-shows the woofer in the 5x7 hole with the black mdf behind 3-shows the drivers side abit neater finish than the pass side i had to rush yesterday 4-closeup of the tweeter and grille 5-finished product. |
#40 | ||
Irregular Member
Oops sorry i gotta delete sum attachments to get the last couple in
#41 | ||
Ford POWER!
What about using 5x7 Splits insted of 6.5's? These should just drop into the old holes? Would the old speaker hole be deep enough to fix a set of Alpine type R splits? Or would i need to use a spacer?
Liquid Silver Ford Falcon AUII XR6 HP Manual ![]() |
#42 | ||
i believe using 5x7 is a drop in replacment yes
#43 | |||
#44 | |||
Irregular Member
#45 | |||
Ford POWER!
#46 | |||
Ford POWER!
#47 | |||
Irregular Member
#48 | |||
Ford POWER!
#49 | |||
No probs, will look for a pic when I get home |
#50 | ||
Uterus M.I.A.
I have Alpine type X splits 6.5" and they go in to doors but the grills wont go back over them. You cant move them inward anymore or they hit the window. Its a case of cutting the door card and building the bottoms out when I get around to it.
#51 | |||
Ford POWER!
#52 | ||
Heres a Type R 5x7 in the front door. I have a layer of dynamat, the factory rubber mat thing a spacer from 6mm MDF and the spacer that came with the speaker to clear the window.
Front I had to cot down the rib things behind the speaker grill and cut part of the trim that sits behind the speaker grill. If I had have realised they werent just going to drop in I probably would have got some differen 6.5" splits but these sound great anyway. |
#53 | |||
Irregular Member
#54 | |||
Ford POWER!
#55 | ||
Phildee, any idea if i'd have the same problems with the Type S 5x 7 splits?
#56 | ||
When mounting the 6x9's under the parcel bench what do they look like from above
#57 | |||
I've got type R 5x7s in the back of my car, with 6.5" type r splits up the front, and bass is more than adequate. |
