#31 | |||
Ute Forum Moderator
![]() Join Date: Dec 2004
They did use Jeep transfer case, diff etc. The main reason they didn't continue with it from what I have read is that the leaf spring mounts fed loads into areas of the body shell that were not designed to take them, basically it was too expensive to design the body intended for coils to take leaf front suspension for the number of sales. Goldie is right too, they used the 6cyl tilted to make room for the front diff, together with the 3 speed manual. |
#32 | ||||
IWCMOGTVM Club Supporter
#33 | ||
DJR TM#54
I didn't know about the AU's going to Hong Kong
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went. Now Zetec Powered. 1.6lt of madness. But the XR8 still remains ![]() |
#34 | |||
fat289
No V8 4x4 ute built period!!!!!!!!!!!!!
I'm just having a great Falcon time , thanks for asking dumba$$ XRGT XP ute 351w Toploader 99 Springer softail XW Fairmont 302w / c4 col shift 58,000 miles |
#35 | |||
fat289
Diffs & transfer cases are cj5? jeep All part no's in Ford book are jeep with 4x4 at the start
#36 | ||
fat289
XYGT went to south Africa/England
XAGT went to Papua Newguinea/Fiji ? XBGT went to England
#37 | |||
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
#38 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ Tuned by LS Tuning and Performance -2022 Hyundai Tucson Highlander Diesel N Line |
#39 | ||
Barra Turbo > V8
Also motor or wheels took an EL GT to germany aswell a guy in the E series forums actually owns it http://www.fordforums.com.au/showthr...=EL+GT+Germany
#40 | ||
AU2 (Oo===oO) XR6
Some interesting stuff never knew they sent the au to asia and el to South Africa i did know about the fairlane in England and i think they got a few fpv's there as well and they sent the gtho to south africa too.
when handling tools make sure the biggest tool isnt you ![]() |
#41 | ||
re
Location: Victoria - where being slow & incompetent is considered being "safe"
Back to the XY 4x4 - If it used a Ford I6 tilted slightly on it's side:
- Did that mean that it used different engine mounts? - Did it use a slightly different inlet manifold so that the carbs would sit "flat"? - How much was the tilt (like a Chrysler Slant) and how did that affect oil flow?
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ |
#42 | ||
growing up is optional
All the engine bay pics I have seen show the engine laying over, will try and find some and scan them. Meanwhile, look here
http://www.4wdonline.com/Ford/Falcon.html |
#43 | ||
From what I can see it appears that the engine is mounted further over to the left and tilted to the right. The scan is a bit hard to make out.
