#31 | |||
V8 wannaabeee
#32 | ||
Aspiring mr efxr
so whens the next one guys? i on my p's in jan. i up for some fun!
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
#33 | ||
Last warning
late january i beleive.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#34 | ||
EBII XR6
is there a thread up for it yet in the events section? or is the date not finalised yet? it'd be great to get a decent amount of e-series up there!
john: yeh you bloody woulda lapped me! i know why tho, its all about suspension and wheels set up. remember you got new struts the day before, also your on SL's compared to my XR6 and Low's combo! your've also got better shocks whereas i'v got stocko's! you have 18" wheels compared to my 15"s!! we woulda been close on the straights but you just killed me through the corners!
DEVLXR
#35 | ||
you just used the slow pedel to much was good fun though im trying to chase up some used race tyers for the next one and a set of 17's
#36 | ||
EBII XR6
yeah it'd be a good idea to get some better wheels and tyres for the day! too bad i cant afford a chocolate bar atm with christmas, sorting out my exhaust and other maintence stuff for the car!!
oh and no i didnt use the slow pedal too much, the car was pushed to the limit a fair bit and the understeer was rediculous!
DEVLXR
#37 | ||
Tuned @ Pitlane Frankston
If the cars getting hot when u give it hell:
change the thermostat flush the radiator (get it done professionally) That will fix it.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
#38 | |||
AU II XR8
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
#39 | ||
EBII XR6
not quite sure but is there a thermo stat with clutch fans? hopefully by next winton fun day i've got thermo's anyway! i've put in new coolant and flushed out the old stuff!
DEVLXR
#40 | ||
Ok, lets cclear some stuff up while we're on the topic of cooling systems.
Every falcon has a thermostat. The thermostat is a device which detects the temperature of the water in the engine, and opens/closes accordingly to keep the car at a operatings temperature. When you hear people say, I put a cooler thermostat in my car, it means that instead of a standard thermostat opening when it hits, for example, 95 degrees, and letting the cooler water from the radiator into the engine to cool it down, they might have a 91 degree thermostat, which will open earlier, and let cooler water through the engine. Basically, this means that the coolant/water should never get hotter than 91 degrees, hence the engine running cooler. Now, the cooler water that goes into the engine once the thermostat opens, is dictated by the radiator. As you drive, the compressed air hitting the radiator cools the water in there. So, when your engines water hits 91 degrees, the thermostat opens, and the cooler water from the radiator will be passed through the thermostat into the head/block and then back out through the water pump -> radiator. As you can see, the cycle starts again, with the hot water from the engine being passed through the water pump and back into the radiator to be cooled. That's a basic cooling system operating. Now, a clutch fan is designed to spin freely when it is cold (not creating any flow through the radiator) and when it gets hot, a small 'clutch' inside the 'clutch' fan engages, and the fan becomes a direct drive to the engine RPM. So, the car is sitting there idling, and the clutch fan is spinning at say, 1/4 the rpm speed of the engine, so cooling it a bit, but not alot. Then you rev the engine, and it heats up. The clutch fan engages at a certain temperature, and starts spinning faster, creating more air to pass from in front of the radiator through the radiator (remembering our car is stationary, no air is passing in front of the car to cool down the water in the radiator, so the clutch fan pulls air passed the radiator by creating a suction when the clutch engages). Now, there another type (and some may say better) of cooling, called Thermofans. Thermofans in an EF, have two fans on a plastic shroud. There is nothing connected to the engine like with a clutch fan. The front of the engine spins freely. Some people believe this is better, as there is no drag created by the clutch fan spinning on the engine, freeing up the revs. Basically, thermofans work by detecting when the car gets hot via the temp sensor, and switching on to create a suction to suck air from in front of the radiator through it, in turn cooling the water in the radiator, so when it gets passed through the thermostat and into the engine, it cools your engine down, before returning through the water pump and back into the radiator to be cooled down again, and then passed back into the engine, and so forth the cycle continues. If your cooling system is not blocked, and everything is in check, when driving a car on the highway where there's plenty of airflow, the thermofans will never come on, because there is enough air passing through passed the radiator to cool the hot water coming from the engine from the water pump. Thermofans will only come on once you become stationery, and the airflow stops passed the radiator, creating the need for air to be passed through to cool the engines water down. Man, that was a long post. Hopefully that was an insight into how a cooling system works. Cheers
#41 | |||
![]() Join Date: Dec 2004
Thanks for taking the time to post that Yagz. Good information
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
#42 | |||
In response i find that the clutch fan works better for my car as i have had the thermo's before, and yes i am running the cooler thermostat or the "summer thermostat as others call it" this set up i find is more effective on the later model e-series falcons. |
#43 | |||
#44 | ||
EBII XR6
yeah very good run down! i actually learnt something then!! cheers
DEVLXR
#45 | |||
#46 | ||
EBII XR6
lol!!nah it made sence to me! i still prefer thermo's tho, even tho clutch fans and thermo fans do the same job and are good at it, i still hate the loud roar of the clutch fan when the engine is hot! thermos are so much quieter!
DEVLXR
#47 | |||
#48 | |||
#49 | |||
However, Thermos can be useless if they arent shrouded properly, like an engine fan they need a shroud to concentrate and pull the air thru the radiator area.
PX3 Ranger - family truckster
BF Fairlong Ghia - boostlounge 11.26 @ 121 |
#50 | |||
Lowriding
Every engine I know off that runs thermos does not have cooling problems, including my engines. Big dollar or not. |
