Old 05-02-2007, 10:58 PM   #31
EA Ghia
EA Ghia's Avatar
Not good news, was looking forward to seeing the car on sunday, probably my favorite car I've seen on the forums. Just waiting for the day to see it in the flesh.
Hope you get it fixed soon, from what I've heard, seems to be problem after problem! :P
EA Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 10:59 PM   #32
dansedgli
dansedgli's Avatar
Bugger steve. nothing is easy with that thing.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 11:05 PM   #33
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Man thats sad to see after all the good work, but battery terminal, come on........................
Wait I can talk we tried push starting a corolla we had after a new engine was fitted for 30 minutes only to find we forgot to put the rotor back in.......lol
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 11:06 PM   #34
-jjM-
-jjM-'s Avatar
**** not good steve my man, sorry to hear you were stuck man
its not all goin as planned is it...
-jjM- is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 11:16 PM   #35
LUXO_8
windsor user
shame to see steve......ive got no ideas as to what it could be but..
good luck sorting it out man....!
Old 05-02-2007, 11:50 PM   #36
Rollin
Rollin's Avatar
Zip tied on front bumpers FTW.
You can put the holes out of the way so nobody will see, and zip ties are quite strong.
If the bar is supported so the zip ties only take fore/aft loads it will not come off unless you want it to - works beautifully when you blow a T5 to bits and need to have you car towed to work...I know first hand ;)
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2007, 12:20 AM   #37
eMpTy
Low, Loud & Black
eMpTy's Avatar
I'll second that.
I'm using zip ties that are about 20mm wide and the front bumper actually fits alot neater than mounting it properly (no gaps at the corners etc).
When it's time for an oil change just have to cut them off and undo a couple of bolts. Too easy.
eMpTy is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2007, 12:43 AM   #38
89 S-PACK
Originally Posted by EA2BA
ok then, was basing it off the backfire which oftens means timing is out and the no starting. Checked the vacuum hose to the MAP sensor.
try swapping the fuel map...
mine backfired on petrol 12 months ago and blew out the centre muffler while it was at it! all what caused it was a lead had come off and the force destroyed the fuel map, the car still ran but not fantastic after that... but changing everything i swapped mine and i was cursing cos thats all it was ( i found the fault after the dyno day in geelong)
Still about lol...
02 (VX) Holden Commodore Equipe series 2 S/wagon.
Manual, Lsd, Catback, Svsi lpg.
still a nice reliable upgrade from the old magna..
89 S-PACK is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 08:20 AM   #39
Kelz
LiL sPeEd RaCeR
Kelz's Avatar
aww pimp daddy.. sorry to hear that.. one minute I hear your coming then the next i heard ur car had broken down.. hope it gets better soon!!!
Yes I own a Renault And Proud Of It!!
Kelz is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 09:26 AM   #40
BI6TIM
SnortPerformance.com
I had a similar problem to this a few months ago with the EL Fairmont Ghia. Drove out of a round about and the thing coughed a little then just turned off. Couldn't start the thing for 3 weeks. Replaced about 4 coils (just in case I had bought broken ones), went through two second hand and one (new but 5 years old) TFI modules and finally replaced the distributor and it started. Timing was way out and it didn't run well but that was easy fixed.
Our car doesn't have gas, but this might help anyway, hopefully.
So at the end of the day I'm not sure if it was the distributor or the TFI (dissy came with one) but it runs now so I'm happy.
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 02:13 PM   #41
EFFalcon
Last warning
EFFalcon's Avatar
Rmyers car is pretty much an EF, so about the only thing that can die is the coil pack.
how ever the car is sparking.
also ignition timing pretty much can't be out.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 08-02-2007, 04:15 PM   #42
Rmyers
Does Steve have a car?
Rmyers's Avatar
My main concern ATM is not to do with the car not running, rather the front bar. Whatever the problem with the car not starting i wouldn't imagine it to be an expensive fix, whilst the front bar is a different story. I now haveto decide whether to fix it myself or to just pay somebody to do it for me. Option one will be the cheapest but the most time consuming (especially at the pace i work at), whilst option 2 will see her ready far quicker but will cost money that i do not have.
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 04:33 PM   #43
bentles
bentles's Avatar
how is it a hard decision? dont have the cash? diy!
bentles is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 04:38 PM   #44
FordGirl
The Goodz' PR Manager
FordGirl's Avatar
Leave the front bar for a while Steve, until the car is running and reliable leave it as it is incase any future tow truck trips are in order.
Either that, or find a way around this happening again. The last thing you want is to either spend a lot of time or money getting it fixed just to have it happen again.
It's GREEN!
FordGirl is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 04:39 PM   #45
Steady ED
Steady ED's Avatar
Steve, when/if you do fix it, maybe give the cooler some more clearance.
I doubt it would have done as much damage if it didn't push up into the cooler.
Spewing but, if you didn't have bad luck you'd have no luck at all! :(
Steady ED is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 06:33 PM   #46
Mr. CVE
If it aint Blown it Sucks
Mr. CVE's Avatar
I think I know what it is.
When you call me I will tell u !
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph
@235 rwkw !!
Now turbo 11.77 @114 mph
320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds:
Now for sale
http://www.fordforums.com.au/showthread.php?t=11296772
Thanks to Snort Performance, Headsex and CVE
Street car DeTomaso Pantera
Drag car 1995 Mustang, Haleys Comet ( It's back !)
Power by CVE
Melbourne's first SNIPER Tuner :
Now tuning E series
Mr. CVE is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 09:08 PM   #47
nos_james
nos_james's Avatar
man that suxs hopfully its back out on the streets soon i realy want to see it gives me some insparation to get back out and work on my car
nos_james is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 09:50 PM   #48
walker
walker's Avatar
that would make a good day bad very quick
Its not peer presure..........Its just your turn!
XE project underway
walker is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 04:29 PM   #49
Rmyers
Rmyers's Avatar
Bit of an update...
Been tinkering with the car for a few days now, just testing various things to try and pinpoint the problem. Not getting any spark on number 1 and 2 leads (despite it working when it first broke down, number 3 lead is sparking tho. We also tried spraying "start ya bastard" into the trottle and there was not so much as a hint of firing up. I've grabbed a test light to confirm that spark is not present, and have purchased a spare coil pack in that case.
If there is spark, it will show me if it's sparking in the correct spot, as if it's not this could indicate whether a sensors gone or possibly a bigger problem such as the ECU.
I've also changed the alternator. While this won't be the problem, it may played a hand at causing the problem. I've been getting very erratic voltage, sometimes it will hover at 13v whilst sometimes it will jump to 15v and over, which could have buggered something especially when the battery terminal came loose. Just theories at the moment, will be heading out there momentarily to see what i can find.
Lastly i've found that one of the plugs that sealed up my injector holes is missing, which would have popped out when the car was backfiring on the day. So this will also need to be fixed before i can try to start her. As for the front bar, i'm going to leave it alone for now, i've got a fair few other things to pay off and can't afford to spend money on vanity items ATM...
I never seem to have luck before cruises or big events, i'm glad tho as my car was meant to be displayed at the chadstone big boys toys display, and i'm damn glad i didn't go there. Perhaps my cars trying to tell me something? Guys, watch out for a TMU ambush at FDC :P
AKA Mr Silver
Old 28-02-2007, 04:50 PM   #50
Rmyers
Rmyers's Avatar
Ok just went out a checked with the test light. Seems that there is no spark on any lead while cranking, but the moment we would stop cranking, it will spark once. Any ideas guys?? Doesn't sound like a problem with the coil packs to me, as i've heard normally one or two coils may die, rather than the whole lot, plus it did emit spark, just not while cranking....
AKA Mr Silver
Old 28-02-2007, 05:41 PM   #51
Dezza
Parts bin special
Dezza's Avatar
Sorry to hear that Steve. Hope you can find the problem and get it going. I want to see NWOLB on the road!
Old 28-02-2007, 06:40 PM   #52
galapogos01
eec tweaker
galapogos01's Avatar
ECU?
Sounds like you borked something when the battery terminal shorted/came off...
galapogos01 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 07:56 PM   #53
efgiar
rofl copter
efgiar's Avatar
try the ecu, or tfi module, if the alt was spiking up to 15 volts it sounds like there is a loose connection somwere, check and make sure all ur earths are tight and clean! if ur alt was spiking (presuming ur using a mitsu alt, could be either a loose sense wire, or a faulty reg but very rarly do those overcharge, usually just die. good luck!
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 08:06 PM   #54
mcflux
mcflux's Avatar
speeeeewing...
And after all the hard work that's gone in to NWOLB :(
