05-10-2005, 12:37 PM | #631 | ||
ef xr8
05-10-2005, 12:43 PM | #632 | ||
Custom User Title
sportsman?
05-10-2005, 12:53 PM | #633 | ||
more posting less lurking
correct nz. Your go
BA XR8 Devil R - SY Territory TX AWD - MQ Nissan Patrol 302c - GQ Nissan Patrol |
05-10-2005, 03:11 PM | #634 | ||
What was the primary reason for the swirl port in the ea cyl heads?
05-10-2005, 03:46 PM | #635 | ||
Two > One
(1) to reduce chamber volume to bring the CR up to 8.8:1
(2) to keep intake and exhaust charges seperated
05-10-2005, 04:21 PM | #636 | ||
To increase swirl promoting better mix of the fuel and air.
05-10-2005, 04:58 PM | #637 | ||
Two > One
Thing is the 4.0 heads do not have the swirl port. Traditonaly a swirl port is used to promote better cylinder charging and to pull intake charge away from the chamber walls.
05-10-2005, 07:13 PM | #638 | ||
eb2fairmont: your on the right track it does do this but theres a reason why they wanted this.
Walki: may be correct answers but not the ones I want. |
05-10-2005, 07:16 PM | #639 | ||
Last warning
coz its a bad idea... as was the EA :P
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
05-10-2005, 08:42 PM | #640 | ||
Two > One
Karl, was it a way of achieving emissions?
05-10-2005, 08:47 PM | #641 | ||
Last warning
Boost
07-10-2005, 09:38 AM | #642 | ||
As an real-time means of destructively testing the longevity of head gaskets?
07-10-2005, 10:14 AM | #643 | |||
Some of these questions are way too technical.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
07-10-2005, 08:47 PM | #644 | ||
BF F6, APV SR3900
attempt to improve fuel economy?
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
07-10-2005, 09:17 PM | #645 | ||
Argh where's my reply go!
The swil chamber was there because EA was orginally going to get EGR. Its primary reason was to mix the exuast gasses properly. It turned out they were meeting emissions without EGR so it was canned. It was too late to change the head casts to the swirl stayed and the heads were changed for the 4.0. AU is also the same deal. I haven't seen an AU head but apparently they have a half swirl. Same deal as ea, was designed for EGR but didn't need it again. |
08-10-2005, 12:08 AM | #646 | |||
Two > One
so.......Here's one which extends into the AU. What is the diffrence in the BBM from EF==>EL and What is the diffrence in the BBM from EL==>AU
08-10-2005, 05:56 PM | #647 | ||
Turbo Dinosaur FTMFW
EL===>AU the maf/air temp sensor is different.
cant remember the difference between ef/el |
08-10-2005, 06:06 PM | #648 | ||
EF, EL and AU all had different mountings for the piping as well as the EF/EL --> AU had different temp/Map sensors
'09 SYII TTG | Mystic '06 BF XR6 | Mercury Silver
08-10-2005, 06:07 PM | #649 | ||
windsor user
the casting on the EF BBM is different to EL, as it has the mounting holes for the EF dual pipe plastic intake.
no idea on AU though edit..bah too slow Last edited by LUXO_8; 08-10-2005 at 06:14 PM. |
12-10-2005, 12:01 AM | #650 | |||
MONTY is Alive !
NEXT ! no au Q's Please !
1988 Ford Fairmont EA Series 1 MODS: Hurricane Extractors, Red dash light, Fake Xenon Lights, Mpfi Conversion, Dumpage, 17" ANZ Mayhems (Chrome) TO COME: 5 speed trans, 4.11 LSD, Carputer, Stage 2 cam, Major Head Work . : |
12-10-2005, 06:39 PM | #651 | ||
what was the answer to the question ?? since it was EA->EL related...
13-10-2005, 11:17 AM | #652 | ||
E-Series Owners Club
All three have different castings for the upper half of the manifold.
The difference between EF-EL was the mounting points on the top of the manifold for the intake piping. The AU manifold has the same mounting points as the EL one, but it has no pipe coming out for the MAP sensor hose to connect to (as the AU had an IAT and MAP in one). The hole where the IAT sensor goes is smaller and doesn't have a thread in it. The area immediately after the throttle body is different (EF & EL look like they have a space for something to be mounted there, but the AU doesn't). And the steel vacuum tree is different (although that can be unscrewed so i don't know if it technically counts as a difference :P). The lower halves of the manifold are all indentical ;) |
13-10-2005, 11:39 AM | #653 | ||
Two > One
Bingo. The last few ideas are all correct.
10-11-2005, 02:37 PM | #654 | ||
Carmon next question hahaha
13-11-2005, 08:11 AM | #655 | ||
yeah, next question, ive been hangn out for ages!
13-11-2005, 12:38 PM | #656 | ||
yep? hook me up with a q.)
13-11-2005, 01:24 PM | #657 | ||
I got a Question
Why is this thread back at the top ? :P |
13-11-2005, 01:28 PM | #658 | ||
because my idiot mate (Stock EB) had to bring it up, i will have a word with him at TAFE tomorrow
