Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
11-12-2022, 12:17 AM | #1111 | |||
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. |
11-12-2022, 07:07 AM | #1112 | ||
11-12-2022, 08:17 AM | #1113 | ||
Regular...with metamusal
11-12-2022, 01:51 PM | #1114 | |||
Is 208A96/208A97 the rubber at the very top of the door on the FG and is it any different on the sedan compared to the ute pictured? Is there a passenger side one still available for an FG sedan? Thanks |
11-12-2022, 08:44 PM | #1115 | |||
Which one do you need? |
11-12-2022, 08:47 PM | #1116 | ||
The XR one please. Out of curiosity, what's the difference? I thought they all just looked like black plastic/rubber
11-12-2022, 08:52 PM | #1117 | |||
I am still trying to get one for crypto, from what I understand, there is only limited stock left so only a few at a time are being released. If I get one for crypto, I will see if I can get another for you. |
11-12-2022, 08:59 PM | #1118 | |||
11-12-2022, 10:25 PM | #1119 | ||
15-12-2022, 02:27 AM | #1120 | ||
Hi GTLegend,
First, thank you for this thread. FGX Power steering pressure switch - G6E Turbo - part number & price incl postage to NSW 2145 please. Is it the sane as FG / Mk2 or different? Regards, George V |
15-12-2022, 08:22 AM | #1121 | |||
On FGX 6-cylinder power steering switch is only available with the whole hose/line, it's not sold separate like other models. Same for turbo and non turbo applications - no difference. Part number BR2Z3A212AA $310 including postage. Same as FG2 all 6 cylinders from 10/2011 on. GT |
15-12-2022, 10:09 AM | #1122 | ||
Thank you GT,
Rest of the power steering fluid lines are not leaking; Switch does not seems to get activated, so time to look for some aftermarket versions. Thank you for your quick response GT. Kind regards, George V |
15-12-2022, 05:25 PM | #1123 | ||
Hi GTL
im after the 2 rubber rectangular gromets that plug into the spare wheel well that can be seen in this link... https://www.kpmmotorsport.com.au/wp-...xhaustTips.jpg 1 is towards the rear bar and the other can be seen towards the front of the spare wheel well. for a 2011 fg sedan. cheers for any help. |
15-12-2022, 05:58 PM | #1124 | |||
Can get these for $15 each plus postage. Cheers, GT |
16-12-2022, 05:04 PM | #1125 | ||
Hi GT,
Two questions: 1) PSP switch - PN: 6G913N824AA, is it the one used in FGX falcon? If so availability & pricing please. It is advertised as for FG Mondeo. Link: https://www.ebay.com.au/itm/233233999368 2) Front bearing hubs, pair - FGX - availability and pricing incl express post please. Kind regards, George V |
16-12-2022, 05:29 PM | #1126 | |||
To answer your questions, you have made me find a possible error in the catalogue, but that is not confirmed. 1. So the power steer lines as per previous threads are the same between FG2 and FGX 6 cyl. FG2 catalogue shows the switch as being available separate as per the number you provided, but FGX does not. So, it can either mean the lines are the same, but the switches are different, and you can only buy the FGX one with the line, or the switches are the same, but they accidently left it off the catalogue. I will need to get confirmation and get back to you. If the switches are the same, I can get for $65 plus postage. 2. Front Hubs are $115 each plus postage. Should be able to get easily enough. No idea on postage as I would need the parts packaged with weights dimensions etc, but at a guess $20 should cover all three items. |
17-12-2022, 12:26 PM | #1127 | ||
Thanks GT,
PSP switch - FGX factory one is stamped with same part number as "Falcon Fg Mondeo''; It is made in Italy. Photo, link: https://postlmg.cc/qg988vsS I will order this and hubs as required after new year. Kind regards, George V |
19-12-2022, 03:40 PM | #1128 | ||
*SILVER SERVICE PILOT*
Hi GT, I'm thinking of replacing the alloy wheel nuts on my 2004 RTV, as the chrome plating is peeling a bit here and there.
Are they still available and do you know what length the genuine ones are? Mine seem to be quite long compared to normal B series car alloy wheel nuts. TIA, Linz.
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271 2006 Lightning Strike BF Fairlane Ghia...HIS 2024 Titan Grey Hyundai Tucson Highlander...HERS |
19-12-2022, 04:00 PM | #1129 | |||
20-12-2022, 11:03 PM | #1132 | |||
20-12-2022, 11:04 PM | #1133 | |||
20-12-2022, 11:26 PM | #1134 | |||
PC200022 by Linz, on Flickr PC200023 by Linz, on Flickr PC200024 by Linz, on Flickr PC200025 by Linz, on Flickr
BUILD THREAD
20-12-2022, 11:49 PM | #1135 | ||
Great that confirms what I have, the 55mm RTV wheel nut has part number EF1012A in comparison to the standard BA chrome wheel nut ER1012A. Obsolete now but might be able to chase some NOS if you are keen. Need to chase availability and price if need be. They used to be around $20 each when they were available.
21-12-2022, 12:25 AM | #1136 | |||
BUILD THREAD
21-12-2022, 04:55 PM | #1137 | ||
24-12-2022, 01:22 AM | #1138 | |||
BUILD THREAD
24-12-2022, 12:50 PM | #1139 | ||
is it still possible to get the rubber drivers door seals au falcon?
2001 AU2 220 XR8 - Build thread |
