Old 17-04-2009, 08:35 AM   #91
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
Well really there is n0 difference in w0t u can get fr0m the end result with a g00d cust0m tune, cause they are b0th d0in the exact same thing, and that is replacing the entire pr0gram 0n the eec with the 0ne either 0n the chip 0r 0n the flasher.
But what we are talking b0ut here is giving y0u the ability t0 c0mpletely tune it y0urself.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2009, 05:18 PM   #92
blackers10
blackers10's Avatar
cheers for that mate
Old 21-04-2009, 08:35 AM   #93
galapogos01
eec tweaker
galapogos01's Avatar
Matt, you said it a lot better than I could
Originally Posted by 5.0whiteaughia
Galap0g0s01 - f0und an interesting setting the 0ther day when playing with mine, the temperature gauge c0mpenstat0r, by changing the values in it, it changes where by gauge sits yet d0esn't effect anything 0n the engine management side.
Nice one. Will send you an email. I think I will have to start looking into AU stuff a bit more closely.
Jason
galapogos01 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2009, 10:04 AM   #94
galapogos01
eec tweaker
Hey guys, have just added support for AU2 XR8 Manual (Smartshield) to the site.
If anyone has an AU which is not supported (i.e. AU2 V8 Auto) and lives in Melbourne, send me a PM.
Cheers,
Jason
Old 29-06-2009, 03:56 PM   #95
galapogos01
eec tweaker
Can anyone confirm if all of the V8 defs done to date have been Smartlock?
It appears that Smartshield is a little trickier than this, and that we can't simply plug a chip in and drive away.
Does anyone have any tips to chip a Smartshield ECU?
Old 29-06-2009, 08:45 PM   #96
5.0 ED
5.0 ED's Avatar
yeah i've done em, works fine, some of the def's are smartshield. And one of them i found the smartshield switch too.
If they having problems then its not being done correctly, has to be the full 256k bin written as it is on the eec, and then only the changes made to it, u can not use a different bin to what was read from the eec, as the eec and bem communicate.
Old 29-06-2009, 10:37 PM   #97
galapogos01
eec tweaker
Hmm.
I pulled the bin straight from the car (AUIII Futura 6 Cyl), and put it on a chip (tried both Moates and T.I.) as is and the car won't crank. No smartshield lamp, nothing.
Now if you've gotten an S2 working OK that makes me think maybe my read was dodgy. Did you have to solder the links on the ECU? The ones I saw both had the resistors present so I assumed links not required.
This is the 2nd car i've had with the same symptoms, the other a AUIII XR8. Getting the ECU out is a nightmare in these things (compared to e-series)!
Old 30-06-2009, 05:21 PM   #98
5.0 ED
5.0 ED's Avatar
Yes if resistors r there then u dont need to solderV anything.
Just double check your bin, data should start at addresses 2000, 12000,22000,32000, make sure you've sent range too 00000-3FFFF on both. Also I used Tunerpro to do all my reading and writing on eec5's, i found the eec editor etc. didn't work.
But yes i have done a S2 V8 Fairlane Ghia with smartshield no probs, so......
Old 30-06-2009, 09:49 PM   #99
galapogos01
eec tweaker
Will email you the bin. Didn't think to pull the bin with the moates, I pulled it with our reader.
Jason
Old 01-07-2009, 11:25 PM   #100
5.0 ED
5.0 ED's Avatar
k my email is out for a couple days, but i'll look then.
I will be doing a S2 AU Fairmont Ghia V8 this weekend, so if i think of anything else off it i'll let u know.
What i will add here is that i have done direct bin comparison's of WALG, one off my parents S2 V8 fairlane ghia, and 1 off another forum member "blueprint" and both were identical, so there is no change in any smartshield code etc in the 256k bin. Both bin's were 100% identical.
Old 03-07-2009, 05:51 PM   #101
5.0 ED
5.0 ED's Avatar
Ok well today i read the eec out of a 01 series 2 fairmont ghia v8, its a WALG is well, its read identical to the other 2 i have, i programmed a chip and yep like u said no go. which is interesting, anyway i didn't have time to go thru and find were i have put the def that i have located the smartshield switch on, so i loaded on a WAFB onto a chip with the smartlock dissabled, and works 100%, now tuned.
I'll go thru at a later stage and find the smartshield dissable, i've found it b4 so shouldn't be too hard lol.
Old 03-07-2009, 06:33 PM   #102
galapogos01
eec tweaker
Ahh! Very interesting news!
Would be keen as mustard to see where this is. Surely the SCT tunes don't all have smartshield disabled, though??? I have heard once a (any) tune is blown in via a Flash Tuner that this security appears to be disabled.
Very curious. Glad im not going insane though.
Jason
Old 04-07-2009, 10:46 AM   #103
5.0 ED
5.0 ED's Avatar
yeah cant answer that one, they run a totally different program to the original so who knows.
Old 04-07-2009, 11:46 AM   #104
galapogos01
eec tweaker
This particular bloke flashed it with another stock tune, then used this stock tune on the J3 to get it going.
edit: maybe this was a pre-smartshield bin he used. if so, he must have then disabled smartlock? hmm.
Old 05-07-2009, 11:58 AM   #105
5.0 ED
5.0 ED's Avatar
ive been comparing the bins for the smartshield switch, i've come up with 12160 on WALG, but i aint got anything to test it on ATM. The none smartshield series 1 read's dont have this in the prog.
Old 07-07-2009, 09:48 AM   #106
galapogos01
eec tweaker
Cheers. Not sure if I will have access to an 8, but any chance you can send through the WALG bin? I thought I had it but I dont seem to. I will try to find this in 12BE, S3 6cyl futura wagon, then test it.
Jason
Old 12-06-2010, 12:07 AM   #107
Sprint347
Tickford
Sprint347's Avatar
Sorry to revive an old thread, but would it be possible to tune an AUIII 5.6 with the tweecer?
If so, it may be an economical alternative to the xcal3... I can get a 'tune' and have it burnt to a J3 chip.
cheers in advance!
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD
AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD
BA XT
SZ Territory TS RWD TDCi
Sprint347 is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2010, 09:05 PM   #108
xr8ute
Back on the road
xr8ute's Avatar
It certainly is possible. You can use the twEECer hardware with the Binary Editor software (which can use the defs discussed in this thread).
Old 13-06-2010, 09:08 PM   #109
Sprint347
Tickford
Sprint347's Avatar
Very interesting, I've got BE 2010 (would have to get a license to do the down/upload), and a tweecer (no-RT).
Might see if I can do a bin dump next time I'm at the car.
Thanks
BA XT
Old 22-08-2010, 11:57 PM   #110
Day-mow
rexnet
Day-mow's Avatar
this is mental
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 24-08-2010, 06:42 PM   #111
EV1LXR8
EV1LXR8's Avatar
ok i have read this thread back to front any im very interested in finding some more information on a xr8 S1 can anyone tell me if you can get a substantial gain in hp with an edit? my car is an ex chaser so dunno if it has a stock ecu, could any one help me get a better edit and do i need to buy anything?
EV1LXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2010, 12:50 PM   #112
Sprint347
Tickford
Sprint347's Avatar
Sorry to thread mine, but will the Quarterhorse product allow me to tune my EEC-IV (2DCA) and EEC-V (12SB) cars and have datalogging?
Old 04-09-2010, 10:06 AM   #113
galapogos01
eec tweaker
Have a read of http://www.tiperformance.com.au/products.html - you will find some more info about my chips etc here.
Not so sure about the QH - support with data logging will depend on whether someone has written a log definition as well as an edit definition for that strategy. As I understand it a few people are using the open edit definitions I provide but that doesn't give you logging.
Cheers,
Jason
Old 04-09-2010, 11:23 AM   #114
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
There is a pretty in-depth thread about this on the fordmods website, where Jason (galapogos01) has charted his progress over the past few years with regards to the development of these chips...
Jason, any update as to the compatibility of AU's with your chips? Have you developed chips to suit ALL variants of AU's yet?
I myself have an AU3 6cyl auto, most definitely interested in getting a chip soon if the results are comparable to a 'tune'.....
Are there any before-and-after comparisons from people who have used your chips as a reference to others who may also be interested??
Old 04-09-2010, 11:48 AM   #115
AUIIPURSUIT
pursuit ute baby
AUIIPURSUIT's Avatar
i have a 200kw manual v8 (s2 pursuit) that a chip with some actual results may like
my ride : AU xr8 pursuit ute
AUIIPURSUIT is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2010, 03:29 PM   #116
Dave_Obsession
I meant comparisons as in dyno graphs....that's what will make everybody sit up and take notice...
Old 04-09-2010, 06:12 PM   #117
galapogos01
eec tweaker
Hi gents,
Results from a remap depend on a lot of things - the abilities of the tuner, how bad the tune was to begin with (how much power there is to unlock), what modifications have been made to the engine etc... the product used to remap the ECU is not important, its more about the tuner!
Having said that, there are a bunch of dyno charts from cars tuned with our products at http://www.tiperformance.com.au/owners_gallery.php - unfortunately no AU owners have uploaded their cars yet but plenty of AU engines in other cars.
Our J3 Chips are fully compatible with the AU EEC-V, and we have unlocked the strategies for most box codes - so if you have a specific question just shoot me a PM
Cheers,
Jason
Old 11-01-2011, 10:39 PM   #118
TUF-427
Hi,what xdf is used for a WALG au2 ecu?
did you ever find the smartshield switch for these in the end as I have one going into a cobra that has the key,bcm etc all removed so will need security fully disabled..
is their xdf groups or familys like the american ecus? gufb suits a9l,x3z etc for example..
also would need to disable auto trans in the Walg,can I use a manual bin and def?
cheers Peter
ps I have various Au ecus at the moment if you want some donated bin files from them..
TUF-427 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2011, 08:11 AM   #119
galapogos01
eec tweaker
Hey Peter,
There's an application chart at http://www.tiperformance.com.au/technical.html which lists the known xdf for each box code. Some do work on multiple bins. Most (all?) have smartshield defined or it can be found by comparison with a hex editor. You can run a manual bin.
If you do dump any that aren't already on the site, please email them to me or zip them up and put them on multiupload.com and link them here so I can add them!
Cheers,
Jason
Old 17-01-2011, 10:59 AM   #120
TUF-427
Cheers thanks Jason,
yes tried the 22CA disabled Smartshield bin and it seems to start and run fine in the WALG ecu,
And also worked in Y3DF I think this is out of AU2 Manual
though I tried turning off the smartshield bit Using the WALG bin and def and didnt seem to work,
do I need to pad these or will Moates flashburn utility do the offsets required automatically?
Can I use these Defs in BinaryEditor?
Also have tunerpro but prefer BE from doing mostly A9L/GUFB tuning to date..
Cheers Peter
