Closed Thread
Old 10-10-2011, 04:47 PM   #91
chevypower
chevypower's Avatar
Default Re: Go Tracey, ACA for the win
The cop: "research has shown...." Proof surrogate fallacy!
chevypower is offline
Old 10-10-2011, 07:04 PM   #92
2011G6E
2011G6E's Avatar
Funniest line I've ever read..."3kph over is more than adequate" and you should be able to keep that under control easily. Really? Honestly?
I just went and had a quick look at the speedo on the G6E...by the spacing on the speedo figures, 3kph would be about a speedo needle and a half or maybe two needle widths wide. It's only calibrated in 5kph increments anyway. That's assuming it's dead on spot on accurate...and it isn't. By the sat nav it's approximately 3 or 4kph fast, so on a highway run I set the cruise control to 103 or 104 and I know I'm actually doing 100 to 101kph.
...erm...
...that's assuming the GPS is dead on accurate...
2011G6E is offline
Old 10-10-2011, 07:49 PM   #93
mr smith
When are people going to get over the fact they are an avoidable tax. I would rather have revenue raised from pea heads rather than an unavoidable tax from my pocket. All the habitual speeders Ive come across deserve every thing they get and some more.
mr smith is offline
Old 10-10-2011, 09:13 PM   #94
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
GST is an avoidable tax too if you import everything from overseas, but people seem to be up in arms about that (IM LOOKING AT YOU GERRY HARVEY).
Franco Cozzo is offline
Old 10-10-2011, 09:31 PM   #95
gtxb67
moderator ford coupe club
gtxb67's Avatar
but don't you get stung with a tax of some form if the value of your items goes over around $900
gtxb67 is offline
Old 10-10-2011, 09:35 PM   #96
Rodp
Regular Schmuck
Rodp's Avatar
...and if you own a Porsche...
Rodp is offline
Old 10-10-2011, 09:44 PM   #97
Silver Ghia
Silver Ghia's Avatar
My FG is probably the easiest car I've had so far to maintain speed at the limit, where I'm most confident not to get pinged by a camera. The large digital speedo in front of me is easy to glance at and is precise, which I've checked with my accurate GPS, showed pretty much the same speeds at 80, 90, 100 an 110kph, and 2 over at 60kph. Coupled with the cruise control with the set speed readout, which I use just about all the time when not following anyone doing under the limit, if I get caught by a camera its because I was pushing the margin.
But then I get into my 1972 MGB. Firstly I need to mentally convert any speed limit into miles per hour. Then there is no cruise control and the accelerator is sensitive at speed. So I need to constantly keep an eye on the speedo but I wouldnt really know how accurate the speedo is anyway, I havent been able to check it with my GPS as there is no power to plug it into. I get an idea of the speedo accuracy from other cars around me, but not sure really. And then the speed check on the Calder nearby hasnt been working for a few years now, so I cant check it with that. Despite the fact the speeds showing on that check tended to vary each time, when it was working. All these factors get combined so there is a bigger risk of accidentally going over the limit. 3kph margin is just nonsense with that car.
Silver Ghia is offline
Old 10-10-2011, 11:13 PM   #98
fmc351
let it burn
Originally Posted by SB076
Different states different rules, Vic no longer has the 10% tolerance (I dont beleive we have offically been advised what the new tolerance is, however I believe its 3k's)
Yeah well IMO thats a valid complaint, 10% always seemed fair to me.
...erm...
actually 10% is fair (for issuing fines), but 3km is adequate (for checking speedo). The statement is in reference to checking the speedo and knowing at a glance that you are over. No need to stare at the speedo to calculate how far over, its easy to see youre over. 60 is pretty well marked and 2-3km is clear to see the needle is past that mark. So, seeing it should be quick, not requiring you to stare at it as is claimed to create the so called danger from inattention to the road due to checking it.
Might want to be careful highlighting how certain vehicles are much harder to do so in, all it says is the cars are inadequate for driving within the law. Some people have no idea what sort of rod they create for their own back.
fmc351 is offline
Old 11-10-2011, 12:50 AM   #99
Falc'man
You dig, we stick!
Falc'man's Avatar
fmc, the point I'm making is people don't intentionally go over the limit, and when they do it usually means they're just driving to the conditions - not racing or driving negligently. The very high percentage of those fined at just 10km/h over is proof that these people weren't speeding, because that's not "SPEEDING", because speeding is when you get fools think they're on a racetrack and start doing 30km/h over.
My point earlier is people should be encouraged to drive without an added pressure of potentially losing their licences. "Just drive to the limit and you'll be fine, you won't be fined" isn't the answer, because guess what, people still stack it due to countless other reasons.
If they REALLY wanted slow people down at least use speed humps in 50 zones, not hidden cameras. The reason they don't is obvious.
Falc'man is offline
Old 11-10-2011, 01:38 AM   #100
fmc351
let it burn
I agree driving to the limit and thats it, is not a safe message and lulls people into a false sense of security. Much like that idiot campaign of bubble driving years ago. But these are different issues to what I responded to posted by Gecko. It was simply the issue that they require you to stare at the speedo which creates danger, I dont buy it due to other things that require far more scrutiny from the person behind the wheel. If you cant manage the simple task of a speedo glance and know what it says, you shouldnt be driving. (not you personally, the generic you) There are much bigger challenges required to be a safe driver.
And the speed cameras as revenue raisers? I dont know anyone who thinks otherwise. They also dont care as its an idiot tax. They would prefer them placed in black spots and outside schools etc, but in the end they dont care that people get done at them. But again, this is a separate to whether they agree with any given posted limit.
fmc351 is offline
Old 11-10-2011, 12:26 PM   #101
spebgtsprint
spebgtsprint's Avatar
You are 100% correct mate - Top Post.
The only realistic way that will make people adhere to the designated speed limit at all times is actual Police Presence on the roads.
And we all know that is always in the too hard basket.
"Ive spent all my money on fast cars, fast women and booze, the rest I've just blown"
XR8 SPRINT
FREE HO
MERC C55 AMG
AUDI A4
spebgtsprint is offline
Old 11-10-2011, 12:32 PM   #102
MAD
Petro-sexual
MAD's Avatar
I've said before, for behavioural changes to occur the punishment needs to be made at the time. Getting a letter in the mail 2-3 weeks later is akin to video taping your dog during the day and giving it a whack when you get home.
More police on the roads more of the time is the best solution.
I have a camera I go through everyday that is just after the crest of a small incline. Trying to manage speed and watch everyone around me is a tough task in this section of road. It's way too easy to creep over after you reach the crest and the road is flat again. And if you drove with the people I drive with around me, you wouldnt want to take your eyes off the road for a second either.
- The Story
MAD is offline
Old 11-10-2011, 12:59 PM   #103
SB076
SB076's Avatar
Not staring at a speedo, but a quick glance (less than a second) if you are travelling at 80k's per hour your car will still travel approx. 20 metres.
There was an ad compaign down here (in Vic) awhile ago (not sure if it aired in Queensland) But it was based on distracted drivers and how they are more likely to be involved in an accident (things like changing a CD etc) So by the same token anything that takes your eyes off the road is going in increase your chances of being involved in an accident (even checking your speedo, however it would be a marginal increase)
VIXEN MK II GT 0238
with Sunroof and tinted windows
with out all the go fast bits I actually need :
SB076 is offline
Old 11-10-2011, 01:48 PM   #104
fmc351
let it burn
At the risk of repeating myself, it takes a shedload more time to check a rear view mirror, side mirror, then headcheck to change lanes. Maybe we shouldnt be allowed to change lanes or overtake either. Its all part of driving, and should be easily manageable.
fmc351 is offline
Old 11-10-2011, 02:44 PM   #105
sudszy
as I said in another thread, for those that cant chew gum and walk at the same time, perhaps they should catch the bus.
sudszy is offline
Old 11-10-2011, 03:26 PM   #106
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
Some here must really love the look if their own posts, very repetitive
What happens when a thread goes around and around in cicles?
It gets locked down, we are done here.
Growing old is compulsory, growing up is optional!
geckoGT is offline
Closed Thread
