25-09-2011, 05:38 PM | #121 | |||
AU DIE HARD
That n no front bar and a few other things got to flush the whole system out for a few Ks then give it the big clean up and bling
25-09-2011, 06:32 PM | #122 | ||
Nice work Whoosha. Glad to hear she lives again.
31-10-2011, 12:45 PM | #123 | ||||
AU DIE HARD
31-10-2011, 02:02 PM | #124 | ||
rexnet
what!?why?
31-10-2011, 07:33 PM | #125 | ||||
Back to Le Frenchy
31-10-2011, 08:42 PM | #126 | ||
AU DIE HARD
Filled the sump again got the front off the motor now just waiting to get a balancer puller that fits and hope its a timing cover issue failing that,, 363 Dart
01-11-2011, 12:55 PM | #127 | ||||
You can't stop the signal
02-11-2011, 10:02 PM | #128 | |||
AU DIE HARD
Finally after 6 months and way to many $$$ I found the culprit thats filling me sump with coolant the coating on the timing case cover looks like it has been sand blasted away and in the very top corner it has worn a small hole
now will go shopping and try again
02-11-2011, 10:10 PM | #129 | ||
5.6L x 2 pilot
Good pickup Whoosha. Who would of thought of the timing cover? Hopefully you can now get his beast sorted once and for all.
Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
02-11-2011, 10:19 PM | #130 | |||
AU DIE HARD
02-11-2011, 10:23 PM | #131 | |||
5.6L x 2 pilot
Stu
02-11-2011, 10:33 PM | #132 | ||
Car parts on the kitchen table, again!!!!!
02-11-2011, 11:36 PM | #133 | |||
03-11-2011, 05:56 PM | #134 | |||||
AU DIE HARD
Gets better still. FORD no longer stock or supply new covers and when they did they top out at $250 plus. No luck with after market either yet as the AU being unique piece of ..... the water pump outlet is rs about to every other windsor V8 .. ah well back to the drawing board Quote:
03-11-2011, 08:10 PM | #135 | ||
Hmm Project XW VAN !!!!
Tig Weld.......
I'd rather be BLOWN than stroked Yella Terra Supercharged Power Output? ENOUGH TO BREAK EVERY THING MORE TIMES THAN I CARE TO COUNT POWERED BY VISA MASTERCARD AND MORE VISA (And now a mortgage extension) Disclaimer : : Anything that seems or sounds illegal is all in my head and due to an over active imagination... :
03-11-2011, 10:15 PM | #136 | |||
5.6L x 2 pilot
Following with interest. Stu
06-11-2011, 01:46 PM | #137 | |||
AU DIE HARD
Most of the stock Ts run low 14s with a bit of a tickle hi 13s is a given the LTD in full flight less the Zorst and spare on a good day low 14s or hi 13s wouldn"t be unreasonable Stu best you get it down here for the next drag day..
Meanwhile back in the XR just took a couple of shots of the water blasting inside the water pump, quite surprising considering it only has 100000ks on it and always had fresh coolant,almost looks like it may have had casting sand left behind and has blasted the coating off . And just for for future reference The 3 medium size bolts from the water pump fit the harmonic balance threads to fit the puller on with the main balancer bolt undone 2/3 s of the way its a easy removal with just the thermo fans taken out,
06-11-2011, 02:28 PM | #138 | ||
AU DIE HARD
And for those with AU V8s www.rockauto.com have a huge range of parts cheap as Just follow the links to Ford then 1998 Explorer and go from there
new Cover same as our part number $88 plus $38 express post 4 day delivery or option 2 with complete gasket and seal kit $188 |
06-11-2011, 02:38 PM | #139 | ||
moderator ford coupe club
good luck whoosh, hopefully it all goes back together well
06-11-2011, 03:52 PM | #140 | |||
AU DIE HARD
06-11-2011, 05:40 PM | #141 | ||
after seeing that Whoosh, i`m thinking those cooling system filters might be a good thing, what d o you think?
http://www.jag-lovers.org/xj-s/book/CoolantFilters.html |
06-11-2011, 06:51 PM | #142 | ||
i was gonna say chemi-weld but i'm too late
06-11-2011, 09:17 PM | #143 | |||
5.6L x 2 pilot
Nice work on the explorer research and timing cover. The water pump bolts in the harmonic balancer. Nice work! Always handy to know! Cheers Stu
07-11-2011, 06:49 PM | #144 | ||||
AU DIE HARD
07-11-2011, 07:53 PM | #145 | |||
Giddy up.
07-11-2011, 08:28 PM | #146 | |||
not here much anymore
2024 F150 XLT
07-11-2011, 08:32 PM | #147 | ||||
Back to Le Frenchy
Both funny AND truthful.
07-11-2011, 08:39 PM | #148 | ||
AU DIE HARD
07-11-2011, 08:54 PM | #149 | ||
Giddy up.
Let us know how you go Woosha.
07-11-2011, 08:56 PM | #150 | |||
2024 F150 XLT
