Old 28-05-2007, 01:35 PM   #1
james22
With da Warlords
james22's Avatar
Unhappy One problem to another
Hi all.
I Replaced the globe in the back of my instrument cluster because it blew a couple of months ago. I had half removed the cluster when I broke the lens. So I though **** it. I'll just buy another, cause it was stuffed anyway.
But when I replaced the lens, I accidentally knocked the tacho needle.
Now I done a search using several combinations (needle, tacho, cluster etc) but didn't come up with anything.
Now when I start the car, the tacho sits on about 250rpm, and with the car off, instead of sitting on zero, it sits hard against the bottom of the cluster (about 1cm below "0" on tacho).
How do I reset / calibrate it?
I tried moving it with my hand, but it doesn't matter where you move it, as soon as you start the car, it will jump right to the bottom, then move up to 250rpm again?
Help please, this is driving me nutters.... :
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 28-05-2007, 03:09 PM   #2
JC
JC's Avatar
1. Take the cluster out of the dash and take the lens off (without breaking it).
2. You need to take the needle off - use a fork to pry it off.
3. Plug the cluster back in (Lens should still be off)
4. Start the car, give it a small rev until needle, which you should be holding in your left hand, starts to vibrate (OK, that bits a joke, but seriously, start the car and give it a blip on the throttle)
5. Turn the car off again (all the way off) and count to 10.
6. Reattach the needle at the zero mark.
7. Repeat step 4 & 5. Needle should be sitting on or close to 0 rpm. (if it's close, leave it - you'll get used to it, and it's hard to reattach it perfectly)
8. If you are happy after step 7, then unplug cluster.
9. Reassemble cluster lens etc and plug it all back in.
Note: If you're not happy after step 7, repeat steps 2 to 7 until the needle sits where you are happy with it.
Your other option is just to add 500rpm to whatever it's displaying. :-)
Ford Performance Club ACT
Old 29-05-2007, 07:41 AM   #3
james22
With da Warlords
james22's Avatar
Cheers JC, your a lifesaver, I was not impressed with adding 500 to the mark lol. I only just figured out where to shift at in 3 months. Didn't really want to learn again.
I'll give it a bash this afternoon, let you know how it goes.
Jamie
Windsor Warlords
AU III XR-8220
Old 30-05-2007, 12:23 PM   #4
JC
JC's Avatar
How did you go? All fixed?
Old 30-05-2007, 10:39 PM   #5
superroo
You can't stop the signal
superroo's Avatar
Or the other way is wind the needle fully clockwise(may need to be lifted above the surround to do so) and you can feel it skip on the shaft. This will just move the needle up so when you bring it back it'll sit at a higher rpm than before. Now you just do the same to adjust it back to zero in the other dirrection.
This has worked for me each time i've played with the cluster
Old 31-05-2007, 05:56 AM   #6
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
Originally Posted by james22
Hi all.
Don't feel to bad as i did the same thing when replacing the globes on my dash.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2007, 08:06 AM   #7
james22
With da Warlords
james22's Avatar
Saving it for the weekend, when I've got nothing better to do. I'll let ya know on monday.
Windsor Warlords
AU III XR-8220
Old 31-05-2007, 08:08 AM   #8
james22
With da Warlords
james22's Avatar
I tried doing that originally, I could feel it skip as you said, but regardless, when I started it the needle would hit rock bottom, and skip back as such
Windsor Warlords
AU III XR-8220
Old 31-05-2007, 08:11 AM   #9
james22
With da Warlords
james22's Avatar
Its a bugger isnt it lol. I thought I was actually pulling on the cluster, when in fact I was actually tugging the lens. CRRRAAACK lol
Windsor Warlords
AU III XR-8220
Old 04-06-2007, 07:54 AM   #10
james22
With da Warlords
james22's Avatar
Cheers JC. Worked a treat. Only took about 3mins and it was all done. Spot on perfect now, Thanks for your help.
Windsor Warlords
AU III XR-8220
Old 04-06-2007, 08:44 AM   #11
mark180227
mark180227's Avatar
how much did the lense cost you?
mark180227 is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2007, 09:40 AM   #12
james22
With da Warlords
james22's Avatar
$46.80 from ford in orange. You can get them for as low at 27 in the city.
Rip off bastards
Windsor Warlords
AU III XR-8220
Old 04-06-2007, 01:26 PM   #13
JC
JC's Avatar
No problem at all.
Old 04-06-2007, 01:27 PM   #14
JC
JC's Avatar
Rip off bastards
Wouldn't clear be better than orange? :togo:
