06-12-2007, 09:27 PM | #1 | ||
not here much anymore
Im after a bit of info on how to run new wiring from the inside of the car to the doors, anybody done this and if so can you help me out a bit?
I need to run 2 new wires to each door to power the doortrim lights Ive just put in, I can see where they go through the grommet to get to the door, but how do I get to that area of the car to put the wires in ie what bits of the dash are going to have to come out. Any ideas on how to make this a painless experience?
2024 F150 XLT
06-12-2007, 09:40 PM | #2 | ||
Wanting a sprint!
i'd say remove kicker panels and undo the plastic to move the carpet back for the back doors, coz i would think itll run through the seal panels and will have gromments on the inside.
If thats the sortta information your after , Good Luck regards Craig
On track for mint turbo falcon |
06-12-2007, 10:04 PM | #3 | |||
FTF Club Moderator
I have had to do this. Or should I say Stav did this for me. Run a power wire from the light that shines on the ignition barrel. You only want the door lights on when that light is on anyway. You can just earth the other wire some where convenient for you.You will need about 2 meters of wire. To go down the steering column, behind the dash, kick panel out the grommet and through to the door.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
06-12-2007, 10:18 PM | #4 | |||
So the grommet I need to get to is behind the kick panel by the soubds of it.
2024 F150 XLT
06-12-2007, 11:00 PM | #5 | ||
FTF Club Moderator
IIRC yes. I can have a look in the morning to check. There is a flexible rubber hose that has the wires in it for the power mirrors and power windows. Just use that grommet to get from in the cabin to behind the door trim.
06-12-2007, 11:00 PM | #6 | |||
You can't stop the signal
The area you need to get to is up under the dash a bit. No parts of the dash have to come off but you will need to pull back the carpet to get to the other side of the grommet.
As for getting wires through, use a piece of wire (my choice was coat hanger) smother it in Vaseline then poke it through the grommet. This will take some playing around. Once through, tape the wires to the coat hanger, cover them in Vaseline as well and pull it all back through. Sounds easy huh? trust me it's not. Plenty of swearing will be done. At least it will probably be easier than mine Cheers
07-12-2007, 08:31 PM | #7 | ||
Found them tonight, well the driver's side one anyway, I think the passenger side is going to be the worst with the ECU wiring everywhere. Its going to be a right bugger of a job methinks.......doh..........
2024 F150 XLT
07-12-2007, 08:34 PM | #8 | |||
Its a sh%t of a job to get wiring through to passagers side. When i ran my new speaker wire i went from the door into the car and managed to fish them down and out past the ECU
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
07-12-2007, 08:41 PM | #9 | ||
Sales Representative
Ah crap... looks like i'm going to be for some fun too... as i want heavier speaker wire and wouldnt mind the door lights in future (when i get matching trims)... so i might run ome extra wires while im at for the future. :P
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
07-12-2007, 08:52 PM | #10 | ||
Wanting a sprint!
Yeah sweet it would save alotta fustration down the track what a pain in the a@# lol.
07-12-2007, 09:43 PM | #11 | ||
You guys could try external door lights on your mirrors instead of inside. Why would I suggest that ? Because that's what our Explorer has. Don't ask, 'cos I don't know!
07-12-2007, 10:21 PM | #12 | ||||
