Old 04-01-2008, 07:18 PM   #1
edroders
edroders's Avatar
Default weird battery warning light
Hey guys, need some help.
i have an AU II fairmont ghia and in the last 4 weeks have replaced the alternater and the battery with new items, but reciently the battery warning light has been coming on and staying on for minutes at a time. Although whilst the light is on the voltage doesn't drop and i have noticed no ill effects. does anyone know if this is a problem and its possible causes? thanks guys.
edroders is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2008, 07:41 PM   #2
peterban
AULTD
peterban's Avatar
Sounds like an earthing issue.
Check all earthing spots around the engine bay.
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2008, 08:24 PM   #3
Also check the main lead to the alternator; they are unfortunately placed close to the engine where they get hot and brittle so they fray and partially break inside. If it feels stiff and brittle you will need to cut of the bit closest to the alternator and ensure you replace it with another very thick high current wire. Use hi amp anderson connectors to join the wires and it will make it easier to disconnect the alternator as well.
Old 06-01-2008, 08:04 PM   #4
BOON250
Mine has started doing exactly the same thing!! Looks like a wiring/earth check is on the cards!
1972 Lincoln Continental Mark IV
460 V8 C6 All original .
Triple Brown 1 owner from new !
BOON250 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2008, 10:35 PM   #5
samsy351
351XB - Underbelly II Car
samsy351's Avatar
Mine too, has done it for ages, but theres been no probs with battery or alternator
samsy351 is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2008, 02:34 AM   #6
edroders
edroders's Avatar
so you've had no i'll effects from it? eg. flat battery.
Old 07-01-2008, 08:57 AM   #7
samsy351
samsy351's Avatar
No nothing at all. It only comes on every now and then -stays on for a while (5 mins or so ) then disappears again. Absolutely no problems though.
Old 07-01-2008, 09:28 AM   #8
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Whilst your In this Situation , let me point out that from past experiance , 9 times out of 10 , this is a Very Good Indication that your Alternator is about to go , Sure it Starts and everything now .. give it time and it will go eventually..
Mine Went a Few Weeks ago , Battery Light Came on one day and a few days later , Driving home at night , all the ABS and Seatbelt Lights came on , headlights Dimmed and CD Player went all in Stages , then she came to a Halt.
Rang Darren at FTG AutoSalvage and he Couriered a BA/BF Bosch 80 Alternator over to the door for $88 Bucks !
So , whilst its still moving dude , get it checked
Daniel
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2008, 05:51 PM   #9
samsy351
samsy351's Avatar
Yeah , im sure mines just a faulty light because its been like it for about 2 years now. But for anyone else - you should get it checked.
Old 07-01-2008, 06:52 PM   #10
blackers10
blackers10's Avatar
when my power steering high pressure line was leaking out hte back of the O-ring in the rear of the pump
it was dripping on the alternator and a few times the battery light would flicker on and off at start up (which alerted me to the leaking Power steering pump)
i grabbed some CRC LECTRA CLEAN in aerosol form at work and sprayed the heck out of the alternator
no more problems .. over 6 mths ago now
Old 07-01-2008, 11:23 PM   #11
last fairlane
last fairlane's Avatar
Cool battery light
Hi guys had the same problem with my AU series 1 had the battery replaced two years ago and the light still comes on randomly tried brake pedal reverse any thing that draws current but nothing battery has never gone flat must have been crook battery 2 years ago disconected leads and replaced them all that did was make me head off to Q Ford with the rego papers and they gave me a code for the stereo still no change so I just live with it JOHN
last fairlane is offline   Reply With Quote Multi-Quote with this Post
