Old 06-01-2008, 02:45 AM   #1
amiers
Default water in the transmission!
is there any way to save the tranny after the radiator has let water in? i am aware of what caused it. the car was only driven about 5 km when it happened. i know this as i had checked the oil and water and it was fine drove down the shops and back, when i got home i had to check something else nad saw the goo in the recovery bottle.
the car has not moved since. about 3 days, should i drain the box? disconnect the lines? or am i screwed?!!!!
amiers is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2008, 03:31 AM   #2
FGII-XR6
FGII-XR6's Avatar
get it towed to a transmission specialist yesterday if not sooner
Old 06-01-2008, 07:54 AM   #3
gravelrash
the cooler in the radiator sounds like it has gone to lunch. big problems..
gravelrash is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2008, 08:17 AM   #4
Mechan1k
Mechan1k's Avatar
Get a trans specialist to look at it ... they can inspect it and see if there is damage ... but best best is a full flush on the transmission inc. trans cooler, etc. And hope of the best.
Old 06-01-2008, 09:15 AM   #5
gregaust
If the water is in there it might be too late .. The water affects the friction materials and glues used in the clutches and bands . You might be lucky in that the oil has got into the cooler and not water back into the trans since the trans oil is at lot higher pressure than the cooling system. If the trans oil looks ok you'll be fine ,if its pink or milky too late ..
Old 06-01-2008, 10:51 AM   #6
InfernoSR
Sales Representative
InfernoSR's Avatar
Get the Trans checked and flushed, then get the Cooling System sorted. I suggest installing a dedicated external Oil cooler and having the internal cooler removed, you will also need to flush the system properly and get it ready for new conditioner.
Old 06-01-2008, 06:32 PM   #7
Chamelion
Ouch, it's threads like this that have me considering the removal of the radiator from the transmission loop in favour of an external one.
Chamelion is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2008, 11:30 PM   #8
blackers10
blackers10's Avatar
ill be doing mine ASAP..
did some inspecting yesterday and the current hose on my external cooler is long enough to be rejoined to the standard metal line .. PHEW
just need to get my brothers pipe cutter
