Old 06-01-2008, 01:33 PM   #1
vince1
Default Alternator
I am looking for information on how to remove and replace an alternator in an AU 2
vince1 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2008, 01:57 PM   #2
au2sw
Blown 5L coming
au2sw's Avatar
just had to repair my alternator just the other day actually...will have to replace it soon though. you need to take the serpentine belt off, disconect battery, unplug alternator and undo nut and bolt holding wiring loom. undo and remove 2 bolts at the front holding the alternator in place (one holds the support bract for the power steer pump) and the bolt on th back holding to the bracket (may be easier to just remove the bracket from the block as well)
i found it easier to do everything with the thermo fans out of the way too. just 2 10mm bolts at the top of the shroud and unplug the fan loom.
alternator just drops down and pulls out from under the car.
hope this helps
col
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2008, 02:14 PM   #3
vince1
Smile Thanks
Cheers, thanks for the info, i will get to work
