Old 24-02-2008, 05:46 PM   #1
BFD83
BFD83's Avatar
Angry Cluster Screw Cross Threaded!
hey guys, well as the title says the right screw to remove the perspex on the cluster is cross threaded..its impossible to get out! i know the only real way to get it out would be to basically brake the perspex but i dont wanna do that so do you think the best idea would be to go to ford and get them to try and get it off? cheers!
BFD83 is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2008, 05:58 PM   #2
howesy
howesy's Avatar
Dont know what cluster you have but on mine there are no screws holding the perspex on it clips in to place. My cluster has 2 screws up the top under plastic cover caps on the perspex that once removed give access to the screws. The screws hold the cluster in and they screw into one of those sheet metal backing clips which may be turning if thats what your refering to.
Can't beat a Windsor for sound and low down torque.
Liquid Silver Pursuit250
Custom gear and diff ratios
ECU
Exhaust
Crow Comp. Valve springs
Adjust. Rollers
Cold air
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2008, 06:04 PM   #3
StealthAu
You can get the handle of a screw driver up the dash and behind the cluster (I can't remember where from). Put a bit of pressure on the back of the cluster und try to unscrew it. You wont break anything.
Old 24-02-2008, 06:05 PM   #4
BFD83
BFD83's Avatar
yeah im talking about the screws in up the top that those plastic covers go over dude.
Old 24-02-2008, 06:06 PM   #5
BFD83
BFD83's Avatar
my mate and his dad tried but it wont work the screw is that badly cross threaded it just refuses to come out and i do not want any scratches or marks on the dash which i know that would happen if u try and push a screw driver in there.
Old 24-02-2008, 08:20 PM   #6
blackers10
blackers10's Avatar
i think he means like from down where the pedals are because a screwdriver is skinny it gets where your arm cant ;)
to put a bit more pressure on it from behind
Old 24-02-2008, 08:30 PM   #7
StealthAu
Exactly, if it doesn't work, you are not going to remove it without breaking anything.
Old 24-02-2008, 09:38 PM   #8
BFD83
BFD83's Avatar
thanks for the advice guys i hope that will work.
