Old 13-03-2008, 01:23 PM   #1
lostdude
lostdude's Avatar
Default help needed...diff hat/cover removal
hey guys in my other thread i broke my diff hat/cover and i just got one today, but i have a problem removing the old cover, i have undone all the bolts but it just won't come off, i tried prying it with a screw driver but its not working.
my only concern is there is this round thing between the diff drain plug and the other diff bolt , you can see it in the picture below it is at the bottom of the diff , what are they? how do i get them out?
thanks guys.
Prev: 98 Au forte :
Now: 05 Wrx
lostdude is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2008, 02:32 PM   #2
FGII-XR6
FGII-XR6's Avatar
looks like a locating pin to me maybe sealant is holding it on
[SIGPIC][/SIGPIC]
Rides:
Old 13-03-2008, 06:48 PM   #3
Davo3460
Mate that is not just a cover it is the diff you will have 2 remove the axels it also carrys the crown wheel
Davo3460 is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2008, 07:19 PM   #4
F6 R-Spec
formerly PURSUIT-250
F6 R-Spec's Avatar
what did you do mate, hit a gutter,
or has the gut's (crown wheel & pinoin) given up?
Is the diff noisy?
F6 R-Spec is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2008, 08:10 PM   #5
lostdude
lostdude's Avatar
thanks au3xr6 , as you said its just guide pins, but because theres one on top and bottom you have to pry the cover off straight, so i had to do both sides at the same time and combined with the old silicon crap on there it was a pain in the back side.
Pursuit, yeap my back wheel hit the gutter in the wet and it knocked the watts linkage off. the hat is alloy so i guess they designed it to break in extreme situations rather than total diff.
Prev: 98 Au forte :
Now: 05 Wrx
Old 17-03-2008, 01:36 AM   #6
F6 R-Spec
F6 R-Spec's Avatar
Lucky no other damage, make sure you get a El or AU one, as the watts link mount on the cover is in a diffrent position as to a EA to ED, but they all fit.
cheers mick.
Old 17-03-2008, 08:35 PM   #7
XEESP_351
Our work loan car got kerb sided by a customer it broke exactly the same as yours..You will be very lucky if it hasnt slightly bent the axle which ever side u hit..I recomend u replace that side wheel bearing and axle too..
XEESP_351 is offline   Reply With Quote Multi-Quote with this Post
