Old 06-07-2008, 01:30 PM   #1
laneman
HSV. I just ate one!
laneman's Avatar
Default power window
The drivers side power window in my 2dor LR has just died. Has anyone had a problem like this? Not sure whether I can just change the motor or I have to buy the regulator as a whole, does anyone know?
Now driving XG ute...
laneman is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2008, 02:41 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
Memory is dim, but I pretty sure I had this problem early on.
I seem to recall it was some corrosion in the connection to the motor in the door.
If you're handy, it may be worth pulling the door card off and cleaning the connections first. If you're unsure on how to do that, invest in a Haynes Manual (4167?). It will cost you the same price as half and hours labour at your local Ford Stealer!!! Good investment
Old 08-07-2008, 07:14 PM   #3
focusrally888
is it just my car or is the power windows really slow in the focus?
focusrally888 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2008, 07:28 PM   #4
blue_focus
Yeh my power windows are really slow in my focus too..Sounds like the motor is gonna die, has been doin this since new but had the car 4 1.5 yrs now and still goin.
blue_focus is offline   Reply With Quote Multi-Quote with this Post
