19-08-2008, 10:49 PM | #1 | ||
Hi guys, ive got an issue that is starting to drive me crazy. All 4 of my doors have been rattling like hell lately when I go over the slightest of bumps. Being a panel beater by trade, Ive been over many many different thoughts and theories on this, and nothing seems to want to fix it, including a new full set of door and turret rubbers. Any ideas and thought and massively appreciated. Thanks in advance.
19-08-2008, 11:02 PM | #2 | ||
krunch krunch hsv 4 lunch
Are these rattles the doors clanging away or the seals rubbing away on each other?
My XR8 use to do the same thing - seals creaking etc which meant there was a slight movement in the doors. I sprayed an old rag with silicon spray and wiped down both sides to the door sills and the silence is golden. |
20-08-2008, 11:54 PM | #3 | ||
Open the doors and lift them up from the ends, see if thats the noise
If you can feel movement, the hinge pins are stuffed, no fix, need new ones there is a plastic piece in the middle that wears out. Assuming all hinge bolts are tight naturally, they can come loose also. This happens to my taxis regularly Another option is to realign the door catch on the B pillar to hold the door tighter, just loosen torx and move or hit it in the required direction, this will work for a while only but |
21-08-2008, 09:04 AM | #4 | ||
Flairs - Truckers Delight
Jastel and ratman speak the truth
i had an awful rattle from the drivers door until i realised that all three torx screws were loose on the door catch so i tightened them up and hey presto! silence! just remember, duct tape is silver, silence is golden.
21-08-2008, 10:16 AM | #5 | |||
Sales Representative
As for the door info... i'll be using that myself when it comes to re-fixing the doors...
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
02-09-2008, 12:53 PM | #6 | |||
Parts bin special
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
02-09-2008, 01:13 PM | #7 | ||
LOW AND SLOW
ratman has the right idea. My AU had this same problem and i sprayed the seals with silicon spray and it worked a treat.
Also as Mr Hardware mentioned, check the torx bolts on the driver's side door catch. Mine were all loose also. Adam.
"Any Color You Like As Long As It's Black, Matt Black, With Flames, And A Bit Of Pinstriping". |
02-09-2008, 05:54 PM | #8 | ||
Checked all of the above, all are good. Its the doors themselves that rattle on thel ocks. They are adjusted right in, and at the moment, the door catch is right up holding the weight of the door, and it still has the rattles.
