Old 31-08-2008, 05:16 PM   #1
dreadly
Default How to change dash fascia on au xr8?
Can someone tell me what steps are needed to replacing a dash fascia on an au xr8?
Would be most appreciated ;)
dreadly is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2008, 05:55 PM   #2
WoodysXR6
Wanting a sprint!
WoodysXR6's Avatar
remove 2 plastic clips at top of cluster then you will see 2 screws under the clips.
Just pull the cluster out and remove maybe from memory 3 wiring harnesses from the back.
Then you'll have the cluster out and just unclip the plastic tabs to remove the fascia you'll see how easy it is once its out just maybe use a fork to help leaver the pins of the fascia,
Just lift the dials off the cluster they will have a few little clips on the outer,They will just pop off with some pressure.
Hope this helps.
On track for mint turbo falcon
WoodysXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2008, 12:52 AM   #3
dreadly
Cheers give ill it a go this week some time...
Old 01-09-2008, 11:42 AM   #4
kcej
2mny projects 2 lttl time
Default just a tip
Mate, after the screws are out they are a pretty tight slide in fit, but sliding out there are parts that can catch.
I had to slide bits of thin bendable plastic between the speedo n dash to get mine out as they are designed to slide IN easy, but don't always slide OUT as easy.
kcej is offline   Reply With Quote Multi-Quote with this Post
