02-09-2008, 07:57 PM | #1 | ||
just looking at lowering the AU3 SR (non irs) falcon and was thinking it might be cheaper to grab some second hand XR springs. are the xr6 or xr8 springs much lower than the sr?
also what model cars can i get them out of? ie would au1 springs or ba springs fit the au3? cheers -tim |
02-09-2008, 08:55 PM | #2 | ||
Just go for au 2/3 xr6 springs,they will be firmer an about an inch lower,if your on a budget
T2 TE50 no:154 Narooma blue AU2 XR8 ute XR4 fiesta |
02-09-2008, 09:03 PM | #3 | ||
sweet.
got stuffed around once before. bought low king springs for a car that was a few years old. the back came down an inch but the front only moved 5mm. after a few phone calls to king springs they came to the conclusion that the front must have sagged on the original springs so the kings springs wouldn't lower it only stiffen it. the coon in the family car so i don't want to get ultra lows, but i didn't want to get lows and have the car sit at the same height. -tim |
02-09-2008, 10:44 PM | #4 | ||
not here much anymore
XR springs should take it down about 30mm BUT I have a feeling that SR's had some sort of suspension pack from factory as part of the SR deal - if so check this out because I wouldnt be surprised if they just whacked XR ones in there anyway.
2024 F150 XLT
03-09-2008, 07:06 AM | #5 | ||
I have a series 2 SR wagon and according to the brochures s2 wagons got sports suspension(xr spring and shocks) but ford help desk suggest other wise.
Its sits at the same height as XRs anyway and is as firm as an XR i can assure you.
03-09-2008, 07:56 AM | #6 | ||
RIP...
I had an AU1 'S', which is likely similar to the later 'SR'.
It had XR springs and shocks.
. Oval Everywhere... |
03-09-2008, 09:48 AM | #7 | ||
bugger. didn't realise the sr's were low from the factory, that throw's a spanner in things. if i called ford with the vin could they tell me for sure what was in it?
might have to call pedders or someone while i'm at it. -tim |
03-09-2008, 11:55 AM | #8 | ||
Life's a Gas
There were at least three spring rates and heights:
Forte/Futura/Fairmont - Standard Height XR = Low Fairmont Ghia = about half way between standard and XR height. Don't knlw what an SR had. Easiest way to check might be to park it next to an XR and see if it's any different. Or else roam your local shopping mall car park with a tape measure, and measure from the centre of the hub cap to the top of the wheel arch for a selection of AUs. |
03-09-2008, 03:44 PM | #9 | ||
Getting it done.....
Best of luck working this one out.....abacus might have the best solution - tape measure and run around a car park??
I've heard a few different versions on the suspension set up of the SRs...my old man has one and when he was buying the car we were told that the dealer had some 'sport suspension' SRs in that were sold, and that our car was the 'normal suspension' SR. I asked the dealer what he meant and i think he had optioned up the IRS from the XR6 (or fairmont ghia??) on some of them. Now whether the standard SR had a lower spring set i don't know (from my eye it seemed lower than the base model on steelies, but that could be the SR body kit....). Another idea is that some ran the XR6 HP (non VCT/IRS) settings, so lowered with xr springs/shocks. What i do know is that a mate of mine recently put his SR on king spring lows and the car didn't drop one iota at the front really.....well not enough to notice.
Dynamic White 1995 EF XR6 Auto Now with: Pacemaker 4499s Lukey Catback Exhaust Chrome BA XR-style tip Airdam Mounted CAI with modified (bellmouth) airbox Trip Computer install KYB shocks Bridgestone Adrenalin tyres Coming Soon: Exhaust Overhaul..... |
03-09-2008, 04:07 PM | #10 | ||
Walking with God
I have a S2 SR sedan and when I put XR springs in it, the height came down an inch.
Bear in mind that you need springs from the XR HP, not the VCT IRS as they won't fit your live rear axle. Hope that helps. GK
03-09-2008, 04:25 PM | #11 | ||
Critical Thinker
Would this sports springs issue be the same for an AU2 75th anniversary futura?
When I drive my car and I pull up next to an SR of the same year, externally feature-wise, the cars are almost identical apart from the badging. Sometimes, I think it looks a tad lower than a regular forte, other times i think its sitting higher than it should. In saying that, my dad's S1 futura sits higher than my car. Could this be due to the different series suspension changes?
03-09-2008, 05:26 PM | #12 | |||
... Fear it!
Shav, baby, your car's like Rik's :P :P
GO Super Lows ;)
Chrysler 300C Sedan
SY Territory Ghia |
03-09-2008, 06:15 PM | #13 | |||
Critical Thinker
03-09-2008, 06:29 PM | #14 | |||
not so stock
Good luck
Liquid silver AUIII XR6, BA scuff plates with Tickford inserts, proudly displaying AU falcon.com stickers, lowered, K&N panel filter with wide mouth snorkle, 2 1/2 exhaust and hi flo cat, Illusion mags, slotted and drilled rotors. Next mods: extractors |
03-09-2008, 07:07 PM | #15 | ||
cheers fipcee i'll give them i call if i ring someone. i've heard of fulcrum through other forums and come highly recommended..
i'll wait until i get the mags on the car before i change the springs, it might not look too bad if the sr already has low springs. -tim |
03-09-2008, 08:31 PM | #16 | |||
Critical Thinker
05-09-2008, 10:04 AM | #17 | |||
_Oo===oO_
Another minor thing to bear in mind Pete is that the front shocks (in factory form) for the AUIII are a little different to the previous series as the front brake lines are oriented in a slightly different position. Just a little cautionary note if you do decide on changing the shocks as well.
05-09-2008, 10:44 AM | #18 | ||
Critical Thinker
cheers Dark Horse
I view my car as a tarted up forte anyway. I reckon your right with the heights though. It certainly is more noticeable. Just needs to be lower for my liking.
