Old 09-01-2010, 12:30 AM   #1
beery1
Default au2 cold starting gas only
i have an au2 gas only when i start it cold i have to pump the accelerator afew times after it starts or it will stop has anyone got some advise beery.
beery1 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2010, 12:51 AM   #2
rag top
rag top's Avatar
When was the last time it was serviced?
Any other mods to the car?
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2010, 09:52 PM   #3
Mechan1k
Mechan1k's Avatar
Could be issues with coolant flow to the converter.
When was the last time the thermostat was replaced ... do you have good condition coolant (and enough in it).
Is the heater core blocked ... reducing the amount of coolant flowing into the converter????
Other things to check is if the idle jet in the converter is clear/clean ... so if there is junk around the solenoid plungers in the converter as well.
Is the vehicle having issues cranking ... does it kick over after a couple of seconds or does it crank for longer???
Just a few questions really.
Old 03-02-2010, 01:21 AM   #4
beery1
thanks for that regards beery.
