03-02-2010, 02:17 PM | #1 | ||
Hi there I just brought a fairmont its a 99 model. But the guages in the dash cluster seem to be playing up. The oil pressure guage every now and then slowly goes right to maximum then comes back down to normall. The fuel guage doesn't read full when the tank is, it sits about 3 quarters and doesn't move down on a long trip untill the key is turned off then back on again. The temp guage doesn't get to the normall spot it should, it only moves up a tiny bit and takes ages. Now the motor is reaching proper temp and i replaced the thermostat but the guage aint working properly. Now the volt guage has decided to read maximum too.
Whats going on any ideas ???? I was thinking maybe bad earth for the guages or something. Thanks in advance
Had EB XR8 AU XR8 220 (awsome car ) AU Fairmont BA MK2 XR6 Turbo Now XDUB |
03-02-2010, 08:32 PM | #2 | ||
sounds like a bad earth. i'd check the battery to engine block and battery to body and make sure they are clean and tight and go from there. good luck
04-02-2010, 11:45 AM | #3 | ||
I have read on here that AU1's especially have a poor Battery>Block earthing. Try adding a large guage earth cable between the two and see if that helps. It's something I have to attend to aswell.
My speedo is playing games at the moment where I will stop at the lights and occationaly the speedo will float between 20 - 40ks even though im stopped.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6. Now...... 2012 FG MK2 XR6 Turbo - Manual & Luxury Pack - 302rwkw 2019 Escape St-Line |
04-02-2010, 11:57 AM | #4 | ||
Oil pressure sender unit.
Clusters are more reliable than the Oil PSU
Au Falcon Ute S2 2001 Lowered on Kings with Bilistien Shocks all round 2.5inch cat back K&N Panel Filter FG XR6 17" Rims 245/45-17 tyres XR6T Snorkle BA front Caliper Conversion 300mm With Bendix Heavy Duty Pads Tow bar Transmission Cooler |
04-02-2010, 12:18 PM | #5 | ||
Treasure your balls?
There is service Ford Service Literature for this problem. They fitted an additional earth lead from the alternator bracket.
Meteorite T3 TS50 ESS |
04-02-2010, 01:15 PM | #6 | ||
Ok thanks ill give the earth thing a try and let you know how I go. Also where are the KM stored is it in the cluster or in the ecu beacuse if I had to get a second hand cluster would it show the right KM on it ????
04-02-2010, 03:35 PM | #7 | ||
Kms are stored on the cluster unfortunetely.
05-02-2010, 06:18 PM | #8 | ||
Wow that makes it easy to fake the KM then. Is there any way to tell if its the original cluster in these cars ?????
05-02-2010, 06:25 PM | #9 | ||||
Flairs - Truckers Delight
