Old 29-04-2010, 07:59 PM   #1
Sox
RIP...
Sox's Avatar
Default XR8 series 3 issues
Ok gents, we have a problem.
The new machine, discussed here -
http://www.fordforums.com.au/showthr...8&page=1&pp=20
is having problems.
There are several issues, pinging, rough idle, and rough transition from no throttle to part throttle.
I suspect they are related and once the problem is found, all 3 issues will vanish.
I have so far replaced with new items -
Plugs
Leads
Fuel filter
No change.
I have swapped over with from my P250 -
O2 sensors
TPS
IAT
PCV
No change.
I have measured and determined they are ok -
Crankshaft sensor
Coil pack
The issues in detail are -
Detonation above 3000rpm under heavy WOT with 95 and 98 fuel.
Very rough idle when cold to the point of almost stalling. When hot it imprives, however is still not right.
When cruising, the transition from idle to part throttle (and vice versa) is not smooth.
The most interesting thing which happened was when I swapped the MAF, it was cured, temporarily.
Next day, the idle was still good, however it began to ping it's nuts off again.
The problems also followed the MAF, in that the P250 had issues. However the pinging didn't, so perhaps the pinging is something else.
I'm stumped at the moment. Any ideas?
Oval Everywhere...
Old 29-04-2010, 08:45 PM   #2
needaXYGT
AU II XR8
needaXYGT's Avatar
carbon build up on the piston heads?
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2010, 09:27 PM   #3
GK
Walking with God
GK's Avatar
Could a cruddy fuel pump/sock be contributing to this?
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 30-04-2010, 07:21 AM   #4
Sox
RIP...
Sox's Avatar
Sounds very plausible, and I guess a stuffed MAF could cause it.
Oval Everywhere...
Old 30-04-2010, 07:23 AM   #5
Sox
RIP...
Sox's Avatar
GK
Dunno, the pinging indicates a possible lean mix, however not sure why the MAF would help the idle.
Oval Everywhere...
Old 30-04-2010, 05:15 PM   #6
Stav
Smile
Stav's Avatar
You have an intermitent air leak...dirty injectors..dying fuel pump..dirty fuel filter?Or...faulty fuel pressure regulator. Check fuel flow first. I use a 2 litre coke bottle and time it for one minute and check it against specs.
Old 30-04-2010, 07:18 PM   #7
Sox
RIP...
Sox's Avatar
Vacuum is good, so no air leaks.
Injectors, possible.
Dying pump, possible though doubtful as it won't ping when the weather is cool.
Changed fuel filter.
Fuel reg, possible, but unlikely.
Today I had a good look in the manifold through the butterfly on the TB, there is a fair amount of oil on the walls.
The oil level is also high, about 20mm over the full mark.
I also raised the PCV as someone else mentioned this in a searched thread.
Will drain some oil tomorrow, attempt to clean the inside of the manifold and see what happens.
Oval Everywhere...
Old 30-04-2010, 08:00 PM   #8
Stav
Smile
Stav's Avatar
Hmm.Try a battery reset.Reset the computer too.Before you get into the harder areas.
Old 09-05-2010, 12:40 PM   #9
urbancowboy
Battery reset? What would this do?
My AU2 XR8 is sometimes a little rough on 0% throttle take offs (its manual) when its stone cold and at other times fine, i figure that there's gunk in the inlet etc. I run a bottle of Ford fuel injector cleaner through every 4 or so full tanks of fuel but i'm thinking that a carbon cleaner might help it out too.
Sox. have you run a bottle of anything through the fuel to clean it that way? have you cleaned your inlet system at all yet? Did it help if you did?
urbancowboy is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2010, 01:12 PM   #10
Bolly
Bolly's Avatar
Hmmm see what happens when you remove some of that over filled sump oil..Being too full can cause a number of problems..high pressures in the crank case causing oil leaks, oil building up in the inlet manifold, idle control sol. etc etc
Bolly is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2010, 02:14 PM   #11
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Yeah Sox, Have you fixed it or burnt it?
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2010, 03:43 PM   #12
5L
[ 5L ]
5L's Avatar
mine had the same problem,
i got mine retuned, but sometimes it re-learns and starts playing up around 1900rpm getting a miss fire is what it feels like.
a re-flash fixes this though.
www.ignitionimages.com
Old 09-05-2010, 09:21 PM   #13
Sox
RIP...
Sox's Avatar
Ok, have replaced the MAF with one from a wrecker and idle is back to normal.
Starts well, idles well, accelerates fine up to 3000rpm WOT, above that, we still have detonation.
Won't be able to try much this week as I have work commitments getting in the way.
I might try a bottle of injector cleaner as it's cheap and quick.
I did try some carbon clean and there was no change.
The inlet manifold still looks oily though, so I may rip it off after the weekend and clean.
The oil has been drained, twas 2L over full! May need time to rid itself of the oil in manifold.
Would be easier to burn it at the moment.
Still things to do.
Keep the suggestions rolling in.
Oval Everywhere...
Old 09-05-2010, 09:37 PM   #14
Windsor220
Now Fordless
Windsor220's Avatar
Make sure spark plugs are correct.
Check EGR is ok.
Engine temp.
Old 09-05-2010, 09:43 PM   #15
cedric
my 220 pinks with normal unleaded and some brands of premium. what about some octane booster a see if that fixes it
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2010, 09:51 PM   #16
Sox
RIP...
Sox's Avatar
I replaced plugs with - NGK BPR5EFS-13 - which plenty here raved about.
EGR? On AU's?
Engine temp is good.
Oval Everywhere...
Old 09-05-2010, 09:53 PM   #17
Sox
RIP...
Sox's Avatar
Even if it did fix it, octane booster would just be a band-aid fix for a more serious problem.
They should and do run on 95 fuel, my P250 does just fine.
It has an issue somewhere.
Oval Everywhere...
Old 09-05-2010, 10:00 PM   #18
Windsor220
Now Fordless
Windsor220's Avatar
Originally Posted by Sox
EGR? On AU's?
Forgot AUs got rid of it. Was thinking the older ones.
Old 12-04-2012, 11:41 AM   #19
madmelon
Default Re: XR8 series 3 issues
I do apologise for the thread mine but I seem to be having a similar detonation problem as was described here. I'm wondering if this ever got resolved...
I've got AUIII XR8 and without octane booster, the detonation from ~3000 onwards is severe. I've only used 98 octane in it for the last year, except once the other day when I could only get 95 and added booster. I've changed plugs (6 heat range, not 5 in an attempt to get rid of detonation), leads, fuel filter, checked fuel pump & sock (has a Walbro which I installed), ignition coils, TB cleaned, oil at correct level, cleaned MAF.
It has a custom airbox/filter/pipe/MAF adaptor made by me but had the detonation problem before and after installation.
Any suggestions? I need this fixed ASAP as I want to go to a track day on 29th of April...
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2012, 04:55 PM   #20
Sox
RIP...
Sox's Avatar
I never actually fixed the problem as such, because I just used 98 fuel.
The car is now sold and I purchased another one, of which it also has had some pinging problems with 95 fuel, though not all.
98 is always good.
I feel they are borderline with 95 fuel, and different brands work better than others.
Oval Everywhere...
Old 12-04-2012, 08:42 PM   #21
cedric
mine still pings with 98
Old 12-04-2012, 09:18 PM   #22
b2tf
not here much anymore
b2tf's Avatar
Mine have always been run on 95 and never had any pinging.
2024 F150 XLT
Old 12-04-2012, 09:26 PM   #23
madmelon
Yeah well I'm unlucky because this is on 98 and I've never heard pinging so bad. It's booked in for service on Tuesday at Ford but I'm not expecting them to find anything- last time a misfire due to cracked spark plug was diagnosed as a slipping clutch...
Old 12-04-2012, 10:01 PM   #24
Donny
Tickford 220kw Windsor...
Donny's Avatar
Mine pings a bit under heavy load on WOT with 98, but only pretty heavy load and up over 3500rpm..
1972 Falcon XY GT 351 Clevo 4V Big Port, 4 Speed Top Loader Manual, Ice Blue....
2002 Tickford AU Series III XR8 220kw Windsor, 5 Speed Manual, Liquid Silver...
Donny is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2012, 10:54 PM   #25
mik
mik's Avatar
just thinking out of the box here, but i get a bit of pinging in my vct from time to time,
when i fuel up at certain servo`s, it`s been mentioned in the past the odd servo not having the fuel in the tanks that is listed on the bowser,
perhaps try filling up from a different servo, the first time i heard the pinging i was on the other side of town and very low on fuel and just put fuel in from a little independant unknown servo,
now it was quite obvious the car was running grouse before i entered the servo , and only a very short time later after it got a gut full of this servo`juice it was pinging it`s guts out as soon as i put the boot into it, a couple of days later i diluted the the crappy fuel with the good stuff from my local.......pinging all gone.
Old 13-04-2012, 06:09 AM   #26
Day-mow
rexnet
Day-mow's Avatar
Good advise!
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 13-04-2012, 07:49 AM   #27
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice.
Fuel pump, replace the fuel pump, they lose there ability to keep enough pressure up to the engine, out of all AU's v8's i've come across 50% of them have a faulty fuel pump.
You can check the fuel pump by simply disconnecting the fuel return line, if its not flowing out of the rail then its faulty and not supplying enough pressure to even open the regulator, however if it is flowing it doesn't mean its not faulty, it just means that it does have enough pressure to open it at "fuel requirement" at the time.
Best way of course is to check the fuel pressure with a gauge into the shroader valve, but do realise you need to go for a drive at full throttle and run it through the rev's to see if it starts to lose pressure under load.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2012, 10:24 AM   #28
BillC
My xr8 was doing the same and it turned out to be the alternator. It was only charging enough to be able to start the car but when running most of the time the voltage was below 11 volts. None of the sensors like this. Put a new alternator on and all went good from then on.
BillC is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2012, 10:38 AM   #29
madmelon
Thanks all! I've already replaced the fuel pump- it's only 18 months old at best and is a Walbro 341/342 (Can't remember which specifically but it doesn't matter).
I pulled the plugs when I did my oil change and, as expected, covered in that rust coloured crap from the octane booster. At that point, I'd run half a tank through without the booster but the plugs showed no sign of carbon deposits at all- only thing on there was the orange crap. If I had to guess, I'd say a lack of fuel. As to the cause, hopefully Ford can figure it out tomorrow. If they can't sort it then I think it'll be off to C&V or Autotech...
Need car ready for 29th of Apr track day and have just dropped 3 grand on other bits so it can be! :(
Old 17-04-2012, 08:38 AM   #30
madmelon
Just remembered another symptom- if I was giving it WOT and it wasn't pinging, at the completion of a shift going back to WOT, it would sometimes ping briefly again. Like there's a problem with WOT enrichment. Makes me think even more that it's a fuel problem of sorts.
