Closed Thread
Old 08-07-2010, 07:32 PM   #1
KURS3D
KURS3D
KURS3D's Avatar
Default catalytic converter on LGP
FINALLY proven
I saw the transport inspecter yesterday and asked about having a cat or not on lpg he said no u do not need to have one but he'll double check
he got back to me today and stated that on a light vehicle running only gas you do not need a catalytic converter on the car for pre 2000 vehicles
2000 onwards you need an emissions test done (with no cat) and if u pass(same or better emissions than factory standard for that model car) they can print you out a statement saying u don't need one
This is what i've been told by the QLD transport inspection agency
do u get it? no. ok let me speak moron for a minute
KURS3D is offline
Old 08-07-2010, 07:41 PM   #2
Serial_Fool
Whipper Snappa
Serial_Fool's Avatar
Sentences and paragraphs, do you know them?
*insert witty quote*
Serial_Fool is offline
Old 08-07-2010, 07:50 PM   #3
KURS3D
KURS3D
KURS3D's Avatar
nope he didn't say i'll ask him on monday when i see him
just remember this is QLD were talking about it may not be the same elsewhere
KURS3D is offline
Old 08-07-2010, 08:07 PM   #4
madmelon
I think he may have been referring to your writing style, not the clause in the law...
madmelon is offline
Old 08-07-2010, 08:21 PM   #5
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Lawlz.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline
Old 08-07-2010, 08:22 PM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
hahaha
Mr Hardware is offline
Old 08-07-2010, 08:27 PM   #7
04redxr8
04redxr8's Avatar
Yes it is Queensland. I had a Police officer on Monday ask me if I was breaking the law. I said no.
He rang his Sargeant to check and then let me go.
Moral of the story. Find the clause yourself, verify it, double check it, and then still expect grief.
What difference would losing the cat do anyway? Especially with how well the current ones work.
04redxr8 is offline
Old 08-07-2010, 08:35 PM   #8
prydey
Rob
prydey's Avatar
on my ebv8, i had a dyno run with just the headers, and then bolted up the rest of the exhaust and did another run, and there was only a few kw different. about 2rwkw from memory.
also, i was told once that if the car was released from factory with a catalytic converter then you had to run one. all egas falcons have one.
prydey is online now
Old 08-07-2010, 08:40 PM   #9
Road_Warrior
Pity the fool
That's my understanding as well. If it's OEM emissions gear, it stays on.
Old 08-07-2010, 08:40 PM   #10
04redxr8
04redxr8's Avatar
[QUOTE=prydey]on my ebv8, i had a dyno run with just the headers, and then bolted up the rest of the exhaust and did another run, and there was only a few kw different. about 2rwkw from memory.
QUOTE]
Not much gain to consider the hassle of a defect notice. Thanks for the info.
04redxr8 is offline
Old 09-07-2010, 10:57 AM   #11
andrewts
White Car Driver
andrewts's Avatar
I've heard that you get a lot better fuel economy without a cat, but I haven't tried it so I can't say.
OzECruisers - The Ford EA-EL, NA-NL, DA-DL & XG-XH Owners Club
andrewts is offline
Old 09-07-2010, 11:37 AM   #12
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
i think in one of the adr's it states any light vehicle made from 1/1/1986 must have a cat convertor fitted.
yift is offline
Old 09-07-2010, 02:58 PM   #13
prydey
Rob
prydey's Avatar
1986 was the advent of unleaded, or when unleaded became mandatory for new cars being manufactured.
lpg doesn't need to run a catalytic converter. if you have dual fuel you still need one obviously but for dedicated lpg, it doesn't. having said that, its obviously cheaper for ford to fit the same exhaust to all cars rather than make a special one for egas cars so they all get a converter.
if you were building a car that was single fuel lpg, i'm sure you could get it engineered and emission tested to not require one.
Old 09-07-2010, 05:47 PM   #14
GasoLane
Former BTIKD
GasoLane's Avatar
Maybe its only for 'LGP' cars and not those with LPG
(Sorry, I couldn't resist that)
GasoLane is offline
Old 09-07-2010, 06:01 PM   #15
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
There are several types of gas systems:
1) Open loop single point gas mixer for older cars with out engine management systems and cat convertors.
2) Closed Loop mixture control for cars with single point gas mixer and also cat convertors, Oxygen sensor and throttle position sensor.
3) Multipoint Gas Injection - with a Manifold Absolute pressure sensor, cat convertors, Oxygen sensor and throttle position sensor.
4) Multipoint Sequential Gas Injection - the bee's knees.......
jpd80 is online now
Old 09-07-2010, 06:31 PM   #16
DJM83
Barra Turbo > V8
DJM83's Avatar
And that gain from NOT having one is? I really dont see the point. Oh wait yes i do
'Im HeKtIk because i dun have to run a cat cause the make my car lezz powafull'
-2011 XR6 Turbo Ute - Lux Pack - M6
DJM83 is online now
Closed Thread
