Old 17-07-2010, 10:35 PM   #1
hfeld4
Default cosworth heads
hey im just wondering if anyone knows if the 2lt twin cam cosworth head bolts straight onto a 2lt pinto motor. and if so how uch will need to be done to motor such s cam and so on and so fourth for it to work properly.
thanks
hfeld4 is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2010, 10:53 PM   #2
justbrett
Cossie head bolts straight on but make sure you use new head bolts as the cosworth items are a one use only proposition. Std turbo cams will work if you're planning to run NA. Compression ratio might be an issue if you're chasing NA power, not 100% sure there but at worst you might have to skim a bit off the head.
Biggest setback with these things is the cost of all the bolt on bits and pieces like cams, intakes and headers, the poms charge like wounded bulls for aftermarket gear. Depending on what you're planning, would probably work out cheaper and easier to turbo the pinto.
justbrett is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2010, 07:55 AM   #3
hfeld4
nah i cant go turbo as i am only a p plater and just wanting a quick little car
Old 18-07-2010, 10:44 AM   #4
JamesR
N/A cossie isnt a simple job.
deffs not cheap either.
you'd be better off just getting a decent cam and carbs for the pinto.
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
