Old 04-01-2011, 09:07 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default IDE cable for an old hard drive
Just a quick one for the more technically minded:-
I have had a mate remove an old hard drive from my old laptop and I wish to extract the data from it and put it on our new computer. I am told I need an IDE cable with a USB end on it so I can plug it in, however I am not sure whether I would need to provide power to the harddrive before I could see and remove the data. My limited knowledge tells me that the USB connection should power the harddrive, is this correct?
This is the cable I am looking at, I dont need anything flash as it will be a once off job. Once the data has been taken off it I will be binning the old HD.
http://cgi.ebay.com.au/USB-2-0-SATA-...item2c539d39a5
Thanks in advance for any advice
2024 F150 XLT
Old 04-01-2011, 09:25 PM   #2
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
That link should give you everything to do it. But it being a 2.5" the USB should be enough to power it.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2011, 09:33 PM   #3
Bucknaked
Bucknaked's Avatar
I've got an external IDE case. Basically, I removed an old IDE drive from a PC during an upgrade and purchased one of these cases to house that drive. Now I use it as an external drive to transfer files.
It's called "Blue Eye O2"
Heres a link to some hardware
http://www.auspcmarket.com.au/products/249/
Old 04-01-2011, 11:18 PM   #4
JamesR
i bought one of those to do a similar thing.
it comes with a power supply that plugs to the HDD, then just plug in the HDD and then USB to computer
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2011, 11:30 PM   #5
Tuddy200
Reaching for 200...
Tuddy200's Avatar
Extactly the kit I use at work, has worked like a charm on more then one occasion helping out friends and family.
Will do exactly what you want.
Tuddy's XR6
04' BA XR6 - Blueprint - 6 Speed with Rip Shift - HD Clutch
2.5"/BFGT Exhaust System with Quad Tips - 4490's Extractors
19" ROH Flares - 20% Underdrives - Interior Colour Coded - Sunroof - BOSS Bonnet
Stage 2 Crow Cam's - Crow Cam's Valve Springs - BPR Airbox
M86 LSD Diff with 4.1s - Upgraded Brakes with Slotted DBA 4000's
Leather Interior - Rear Power Windows
Projects Underway: Sound System
Tuddy200 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2011, 11:42 PM   #6
Ptbl
Ptbl's Avatar
Hey mate I bought this exact kit a whiling ago very easy to use you have everything their including the power. Good luck mate.
fordforums.com.au/showthread.php?t=11329125
The XR Build That I Shouldn't Of Sold
DAMN!
Current Daily: 2019 Ford Ranger Raptor
weekeder: 91 soarer
project: 2005 Bmw e46 coupe 1jz
bf mk2 xr6 ute magnet
Ptbl is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2011, 11:47 PM   #7
BA Bakes
It's Cat huntin season...
BA Bakes's Avatar
Hey mate, Got something at work that will do the trick. Let me know you what to borrow it
XRB055 - Black BA MkII XR8 Ute.
6 Speed manual, Leather seats, hard lid.
To do list - Cat back exhaust, new wheels, new shock and front sway bar, and whatever else seems like a good idea
Old Ride
XR40RD - Phantom BA XR6
160 rear wheel killer wasps - Pacemakers - 3" HiFlo Cat - 2.5 Redback exhaust - 18" Speedy Graphite Rims - Dumped on King Superlows - Standard ICC with iPod cradle, 5x7" Boston Acoustics, 12 Alpine sub powered by 4 channel Alpine amp
[/SIZE]
BA Bakes is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2011, 12:10 PM   #8
b2tf
b2tf's Avatar
That'd be fantastic mate, can I grab it off you one afternoon this week and I'll just drop it up when I finish it?
2024 F150 XLT
Old 05-01-2011, 03:29 PM   #9
xisled
You could buy something like this
Silver 2.5in HDD External Enclosure, Aluminium, USB2.0, for IDE drives
MIT-HD25-U2
Listed in the above site. This means you can keep the drive as a backup, and it just plugs into the USB. Turns it into an external hard drive.
I use these on all older hard drives.
xisled is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2011, 03:39 PM   #10
BA Bakes
BA Bakes's Avatar
No worries mate
Old Ride
[/SIZE]
