Old 14-08-2012, 11:27 PM   #1
bartsau
bartsau's Avatar
Default Help needed to identify an unknown connector!!!
Hi all,
I am currently well on my way to converting my wagon to V8 however, there is 1 plug that I can not for the life of me figure out. There is nothing near it that I can think of that it should plug into either.
I must say also a huge thanks to Pinkbits for allowing me to view and take photos under the hood of his TL50 in order to figure out how to put everything back together under the bonnet.
Stupid me never took photos taking the V8 out of the donor car so had no idea how to put lots of it back together.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2012, 07:56 AM   #2
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Default Re: Help needed to identify an unknown connector!!!
driving lights?
what colour are the wires going into the sockets?
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2012, 08:15 AM   #3
block58
block58's Avatar
The second oxygen sensor?
FG MkII G6 Ecoboost in Lightning Strike
block58 is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2012, 08:31 AM   #4
hales231271
hales231271's Avatar
Air temperature sender possibly.
Sensor is in the air intake pipe.
hales231271 is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2012, 11:55 AM   #5
bartsau
bartsau's Avatar
The intake air temp sensor sits up near the throttle body. Same plug but already accounted for.
Oxy sensor also is accounted for.
However, driving lights or something along those lines is very possible. I know the loom I have used there is from an AU III XR8 ute.
I will check the wire colours tonight.
Thanks,
Rhys
Wagon Build
Toy Car Build
Old 16-08-2012, 09:23 AM   #6
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Rhys, I believe what you have attaches to the AC. Attached to the compressor is a odd shaped assembly of piping. I believe that connector connects to this piping. That might be it partly concealed in the top of your photos, but I can't be sure.
Hope that helps
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is online now   Reply With Quote Multi-Quote with this Post
Old 16-08-2012, 09:55 AM   #7
toyotaxr8
toyotaxr8's Avatar
Dude i am 99% sure you have run that wire the wrong way, That wire runs down to the Passanger side ABS sensor right? If so what you have in your hand is the EVAP canister purge solenoid connector, it will have a red wire and a yellow wire with a dark blue trace.
That wire group should run back out gard and down to the ABS and EVAP canister with one of those push in wire ties to the chassie rail to suport the ABS wire
MR INCH
toyotaxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2012, 01:08 PM   #8
lotus
Where does the loom go to after the plug. I just had a look on my SER 1 xr8 and there seems to be a loom that goes through a hole mabye to the indicator or I think the carbon canister as I'm sure it's there somewhere.
We salute those brave souls that enter the DARK side
lotus is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2012, 02:57 PM   #9
bartsau
bartsau's Avatar
Thanks guys I will have another look at it tonight. It may be the same as the abs sensor plug I think of the top of my head. It is definitely not to do with the air con as those plugs are different. Also not the indicator as they are a different plug as well. I am thinking it may be something to do with the abs and the carbon canister as I may have them the wrong way around. Will check and find out for sure tonight.
In other news engine bay is almost 100% complete
Wagon Build
Toy Car Build
Old 16-08-2012, 02:59 PM   #10
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Watch this space Rhys. I have got a photo for you. I just need to get it off my phone.
Stu
2002 AU II LTD
Old 16-08-2012, 03:51 PM   #11
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Rhys, here is a pic of where it goes. You can see the edge of my AC compressor down the right hand side of the pic. There is the little white connector and then the one you have shown in your pictures connected to the piping as described earlier below it. The main compressor plug shown in your pics above your hand is right at the top of my pic.
Hope that helps.
Stu
2002 AU II LTD
Old 16-08-2012, 07:11 PM   #12
GK
Walking with God
GK's Avatar
Seems like the mystery is solved.
Nice work AUvians!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 16-08-2012, 11:17 PM   #13
bartsau
bartsau's Avatar
Ok so it would appear I think that this connector is actually meant to connect to the carbon purge canister. However, for this to plug in there means I would have to disconnect the ABS??
Thanks for the pic stu. But it appears I have made a little mess of the wiring here :/
I will go and have another look now and see what I can figure out. Also, the colour of the wires is a larger pink one and then a smaller yellow with a blue trace which fits with the ford diagrams saying the purge tank is Red and yellow/blue.
Wagon Build
Toy Car Build
Old 16-08-2012, 11:29 PM   #14
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
If this helps - the purge canister has a solenoid which operates it, meaning that the connector will provide battery voltage on one of the wires.
A wheel speed sensor will use reference voltage. Thus, there will be 5v provided on one of the wires.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2012, 11:31 PM   #15
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Oh poo! I thought that I was on to your issue. Bugger.
Sorry Rhys.
Stu
2002 AU II LTD
Old 17-08-2012, 12:04 AM   #16
bartsau
bartsau's Avatar
Problem solved!!
Turns out I am a goose and had incorrectly run the wiring to the for the ABS and hence the loom was a mile to short to reach the carbon purge thingys solenoid. But with running the wires out through the guard both can be reached
Thanks for all of the help and ideas everyone. I think without that it would have taken me a lot longer to be able to figure out my mistake.
All sorted
All connected up properly
Wagon Build
Toy Car Build
Old 17-08-2012, 08:21 AM   #17
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Nice work Rhys
2002 AU II LTD
Old 17-08-2012, 05:07 PM   #18
GK
Walking with God
GK's Avatar
Thumbs up Re: Help needed to identify an unknown connector!!!
Originally Posted by auIILTD
Nice work Rhys
+1!
You're a handy fella for sure Rhys!
GK
Now gone!
On LPG
