Old 20-08-2012, 11:35 PM   #1
alee79
Unhappy Something is wrong with my indicator
Sometime it flashed slowly, and getting slower and slower, then stopped flashing at all, and the green arrow on my dash stay on there.
Is it an easy problem to fix?
Anyone know how to fix it?
Thanks in advance!
alee79 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2012, 11:46 PM   #2
faalcon
Default Re: Something is wrong with my indicator
Check if you have any indicator lights not on. If indicator lights on more than likely flasher cube needs replacement. (located in fusebox)
faalcon is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2012, 05:56 AM   #3
The Monty
Just slidin'
The Monty's Avatar
Indicator relay, as said above. Its a pretty cheap fix as well.
You can also just get in there and give it a clean, or a wiggle, sometimes it can make it work again for a while.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 21-08-2012, 09:35 AM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
step 1. locate flasher relay (see below diagram)
step 2. remove
step 3. whack it on the concrete/gutter/road about 5 times
step 4. replace
step 5. try, find it works, say 'why the hell did doing that fix it?'
step 6. from now on realise that that the tick-ah-tick-ah comes from the little cube relay in the fusebox and not behind the little green arrow on the cluster
step 7. do a burnout
Old 21-08-2012, 07:24 PM   #5
sirchAU
'mechanically-challenged'
sirchAU's Avatar
step 4. replace
The above worked for me
sirchAU's Galaxy Blue Falcon S
sirchAU is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2012, 07:54 PM   #6
GK
Walking with God
GK's Avatar
I'd change the relay.
Mr Hardware has got the good oil!
Quick and easy to do.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 21-08-2012, 10:17 PM   #7
alee79
step 2. remove
step 4. replace
So the flasher relay is the R5?
I will try your steps, hopefully it will work
Thanks mate.
Old 21-08-2012, 10:39 PM   #8
BHDOGS
Yup r5 should be a black box with 3 pins
Old 21-08-2012, 11:21 PM   #9
robbyj
Rob
robbyj's Avatar
remember, only do step 7 when indicator is safely working again.
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
