Old 28-01-2015, 03:06 PM   #1
Rob1964
Default Cigarette odour!
Hi guys I have still got slight smoke smell in my FG F6 2008 I took out the filter under the glove box & cleaned are there anymoe filters or tricks to eliminate completely cheers
Rob1964 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2015, 03:20 PM   #2
BradEL
BradEL's Avatar
Default Re: Cigarette odour!
If you know someone with an ozone machine then use that. I use it at the dealership I work at and it completely removes the smell in an hour
BradEL is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2015, 03:26 PM   #3
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
If you want to cover the smell go to the supermarket and buy a bottle of 'Nil Odour' from the air freshener section- it is only 50ml but 1 drop placed somewhere in the cabin will cover the smell and last quite a while. Use more and it will burn your eyes!
The last car I had that smelt of ciggy smoke I just washed down as much of the interior as I could and drive around for a while with all windows down. It worked - eventually.
___________________________
Old 28-01-2015, 04:05 PM   #4
Ross 1
Mine was same, I turned aircon on full speed on recirculate and sprayed Glen 20( lemon) a lot of it and closed the doors. Left it running for 5 minutes, seemed to do the trick. I did also change the filter in the glovebox.
Ross 1 is online now   Reply With Quote Multi-Quote with this Post
Old 28-01-2015, 05:00 PM   #5
snopony
snopony's Avatar
Yup Glen 20 works as well as Bositos Eucalyptus spray from coles or woolies. I emptied half a can n left the car closed up overnight.
snopony is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2015, 07:20 PM   #6
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Spray all the surfaces with Fabreeze and the smell will be gone.
MINE- AUII Forte
Old 28-01-2015, 08:34 PM   #7
nuthin' fancy
Lyminge, Shepway, Kent
nuthin' fancy's Avatar
Try this:
Mel Brooks sums it up best;
"Comedy is when you fall into an open sewer and die, tragedy is when I get a paper cut"
nuthin' fancy is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2015, 12:11 AM   #8
Ford_The_Win
Another vote for Febreze, it's what I use to keep things smelling fresh. I spray my car seats and carpet with it every now and then to get rid of smells. This is the stuff you want, is usually with the fabric softener and ironing starch in the supermarket.
It's not a perfume that masks bad smells, it contains a chemical called cyclodextrin which traps odour molecules and evaporates them away as the chemical dries out. Also great to keep mattresses and lounge suites fresh. For $6, it's worth a shot.
2011 FG XR6 Sedan
Ford_The_Win is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2015, 12:28 AM   #9
Rob1964
Thanks guys I now have some ammo to kill it off for good
