Old 12-07-2016, 06:48 AM   #1
Sioso
irregular member
Sioso's Avatar
Default LSA for Commodore?
http://www.drive.com.au/motor-news/h...11-gq2xai.html
Holden's swansong SS Commodore could go out with HSV GTS-styled bang, according to fresh reports.
Two American publications claim the final Chevrolet SS – the Holden Commodore twin that is re-badged and exported to the US – will soon receive the same 6.2-litre supercharged LSA V8 currently reserved for HSV's highest powered variants in Australia, including the GTS, Clubsport R8 LSA and Maloo R8 LSA derivatives.
GM Authority says the developments will reach the US production car as part of 2018 updates, the final tweaks before the Australian-built Commodore and Chevrolet SS are laid to rest at the end of 2017. Given the Chevy SS is produced on the same Adelaide production line as the Commodore, the upgrades stand a chance of extending to models Down Under.
Holden Special Vehicles, Holden's official tuning arm, first introduced the LSA to its range in 2013, unleashing the 6.2-litre bent-eight in the 430kW GTS. Developments soon followed on models lower in the food chain, with HSV expanding its range of LSA-equipped models in 2015.
The changes in turn allowed Holden to uprate the regular SS Commodore from a 6.0-litre naturally-aspirated V8 to 6.2-litre naturally-aspirated V8 as part of VFII upgrades in 2015, while still allowing a degree of separation from HSV's portfolio.
Holden declined to comment on the matter. At the launch of VFII, the car maker hinted its current 6.2-litre V8 would be the final major change to the car.
As revealed by Drive last year, HSV is set to leverage the GTS further away from the garden-variety Commodore in the coming months, introducing a higher-powered derivative that is likely to be called the GTS-R and limited to less than 150 vehicles.
The changes mean that Holden could successfully introduce a limited run of LSA-powered Commodores without cannibalising HSV sales.
Advertisement
Chevrolet in the US told Autoblog: "There are no engineering/performance changes to the SS for 2017." But when pressed on the 2018 model or beyond, a spokeswoman declined to comment.
There are plenty of questions surrounding the LSA Commodore upgrade, namely its price and mechanicals. The LSA engines fitted to HSV models at present require stronger gearboxes – the manual takes a twin-plate clutch unit while the automatic is a larger truck-like transmission borrowed from the CTS Cadillac – along with additional cooling for their engine, gearbox and differential. This was at the strict request of General Motors when HSV decided to introduce the LSA in 2013.
The extensive mechanical upgrades mean a potential supercharged Commodore may be limited to the flagship SS-V Redline, while other derivatives would persist with the latest 6.2-litre V8. Given the current base model Clubsport LSA is priced from $80,990 plus on-road costs, the Commodore would likely be priced from $70,000 and limited to a strict run of production in order to be competitive.
Sioso is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2016, 07:24 AM   #2
au2000
AKA "the other bloke"
au2000's Avatar
Default Re: LSA for Commodore?
I'll believe it when I see it
Her's: 2000 AU II Fairmont Ghia 75th anniversary VCT meteorite & 2014 yaris - white
His Toy: 2012 fg II GT-E, emperor red
His: VS Ute 5 Litre 5 speed (povo pack)
His: 2012 FG II GS, Vanish
His: 2003 BA GT-P, Lightening Strike
Jnr: 2002 AU III Falcon XR6 ST, 5 speed Blueprint & 1978 XC Fairmont Neptune Blue
Previous:
1976 HX 50th Anniversary Kingswood
2014 FGX G6E Turbo
1980 XD Falcon GL
2003 BA Falcon XR6
1991 EB Falcon S
1989 EA Fairmont
1982 XE Fairmont
1968 XT Falcon
au2000 is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2016, 08:51 AM   #3
Wretched
Render unto Caesar
Wretched's Avatar
I'm skeptical, wouldn't make sense.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson
Wretched is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2016, 09:17 AM   #4
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
What they'll get is the Clubsport when that goes exclusively LSA, which is what I've read here elsewhere.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2016, 01:23 PM   #5
Junkyard-Dog
*barks incessantly
Junkyard-Dog's Avatar
I wouldn't even be slightly surprised if they did it. Holden have a track record of aiming to please the enthusiasts more than Ford Australia. They had the cojones to build an AWD Commodore, they will put the LSA in their final one.
Junkyard-Dog is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2016, 01:41 PM   #6
FGX-351
Supercharged Mang-mobile
FGX-351's Avatar
I think they'd be crazy not to go out with a bang like that.
09/00 VX HSV XU6 Build #0001 of 0171
http://fordforums.com.au/showthread....09#post5571209
-- Best E/T: |14.982 @92.12mph | R/T:0.013 | 60' 2.213| 330: 6.283 | 1/8: 9.624 @ 73.17mph | 1000: 12.529 | 25Deg, N/A Hum, 1010mb | Willowbank Raceway 7/12/16
Tickford EL Falcon XR6 RIP
-- Factory Manual
-- Best E/T: |14.991 @ 92.71mph | R/T: 0.607 | 60': 2.215 | 660': 9.665 |13Deg, 86%H, 1024mb, 184RA @ Willowbank Raceway
FGX-351 is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2016, 01:51 PM   #7
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
Jdub special edition, like i said 12 months ago.
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2016, 10:24 PM   #8
duaned
duaned's Avatar
Another reason for Holden to scalp buyers by overpricing this potential car.
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2016, 10:27 PM   #9
Smoke Pursuit
Ill buy one in a ute if they do!!
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2016, 12:42 AM   #10
Dave R
Member
Technical Contributor: For members who share their technical expertise. - Issue reason: Valued contributor especially in the FG threads. Offers help and information to all. Posts are always in a positive manner.
Not sure how they'd pull it off. They'd be asking near-HSV money, so folks would either just buy the HSV or save a buck and buy the Commodore, not sure how that would play out. They'd definitely be competing for the same sale however. Maybe if the Commodore was a very limited, numbered edition, they could coexist briefly. Also keep in mind that there's a next generation Commodore coming, AWD with a turbo 6, which will be around the 300kw mark. That probably explains why Holden have been so restrained with the LS3's output- if they make it too potent, there's no incentive for current owners to update to the next model. So I don't see them throwing any more power at the current car during the next 12 months, unless it is a very limited edition.
Dave R is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2016, 02:18 AM   #11
Express
Bathed In A Yellow Glow
Express's Avatar
There's a lot of marketing sense in what you say and if the price was up around the HSV price point it would most likely make the HSV the better option and more so if HSV start doing deals like they have to ward off the current Redline popularity.
Express is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2016, 10:43 AM   #12
Strange1
They should announce it, build 2, enter them in the GT series and win some races and then declare that they aren't viable to sell....
Strange1 is offline   Reply With Quote Multi-Quote with this Post
