Old 20-07-2016, 09:29 PM   #1
superyob
Default Schrodinger's cat
Crazy Dazz, you made my head hurt again. Stop posting words...
https://en.wikipedia.org/wiki/Schr%C3%B6dinger%27s_cat
By the way, you can fix your car with a sprinkling of pixie dust and Bluey's assoff. Your local leprechaun should have all you need...
superyob is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2016, 10:05 PM   #2
wodahs
wodahs's Avatar
Default Re: Schrodinger's cat
putting a cat in a box ! is that anything like putting a rat in a microwave ? no that's just wrong so kiddies don't do that at home mum gets upset
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2016, 12:06 AM   #3
Junkyard-Dog
*barks incessantly
Junkyard-Dog's Avatar
Yeah, we've all seen The Big Bang Theory.
Junkyard-Dog is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2016, 09:13 AM   #4
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
My head hurts after reading and trying to understand (and not understand) the link at the same time....
___________________________
Old 21-07-2016, 10:26 AM   #5
wodahs
wodahs's Avatar
Originally Posted by Yellow_Festiva View Post
trying to understand (and not understand) at the same time....
may be trying to understand it this way ive bought a few Schrödinger's clevelands in my time trying to ascertain at point of purchase if its worth the money or not wether its the brilliant runner they are trying to make it out to be or in dyer need of rebuilding and at that point I wont know till I either open it up (which is usually the best way) or fire it up but I still need to get a price on it and obtain it either way first
as for the other experiment , well I let you call it Wodahs's rat
Old 21-07-2016, 10:50 AM   #6
superyob
So there are 2 possible states a Schrodinger's Clevo could be in? Either running or not. But can't be both? Is that the thrust of the cat example???
Old 21-07-2016, 10:51 AM   #7
Junkyard-Dog
*barks incessantly
I see what you did there
Old 21-07-2016, 11:41 AM   #8
wodahs
wodahs's Avatar
your not meant to look in side the box to see otherwise its a failed experiment
Old 21-07-2016, 12:57 PM   #9
Junkyard-Dog
*barks incessantly
Omg lol.
Old 21-07-2016, 06:09 PM   #10
xtremerus
FG XR6T trayback
xtremerus's Avatar
No ,it can be both. And probably is both, but each in a parallel universe.
The engine is a balltearer if you happen to be in the right one.
Or completely worn out in the other. But you can't chose.
xtremerus is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2016, 06:39 PM   #11
wodahs
wodahs's Avatar
so now we leap from a thought experimental paradox to a quantum physics string theory
steady on there im only a truck driver here slow down a bit and let me get my head around this one and get up to speed
Old 21-07-2016, 07:15 PM   #12
superyob
I'm going to cogitate on this for a while before I pass out...
Ok I am awake again!!! Substitute cat for Clevo if needed...
Schrödinger's cat: a cat, a flask of poison, and a radioactive source are placed in a sealed box. If an internal monitor detects radioactivity (i.e., a single atom decaying), the flask is shattered, releasing the poison that kills the cat. The Copenhagen interpretation of quantum mechanics implies that after a while, the cat is simultaneously alive and dead. Yet, when one looks in the box, one sees the cat either alive or dead, not both alive and dead. This poses the question of when exactly quantum superposition ends and reality collapses into one possibility or the other.
https://en.wikipedia.org/wiki/Schr%C...ingers_cat.svg
Old 21-07-2016, 07:31 PM   #13
mike_nofx
mike_nofx's Avatar
It's like sitting in the car with engine off but your hand on the key ready to turn the ignition on.
Before you turn the key, the engine is both in working order but also not in working order. 50/50 chance it'll fire up, only confirmed once you turn the key.
Sadly I've owned cars just like this, they were Holdens though.
mike_nofx is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2016, 07:32 PM   #14
CoupeKing
I thought the Canaries in the mines had it tough. But a radioactive pussy? Franchise that.
CoupeKing is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2016, 07:40 PM   #15
superyob
Does this depend on engine/cat condition??? Although I don't think that matters???
Old 21-07-2016, 07:57 PM   #16
wodahs
wodahs's Avatar
Originally Posted by CoupeKing View Post
radioactive pussy!
atleast cardboard box's only chafe
Old 21-07-2016, 08:13 PM   #17
Crazy Dazz
Not Quite.
The Copenhagen Interpretation of Schrödinger's Clevo basically says that an unstarted Clevo exists in ALL possible states.
ie, it is rusted solid, and fully reconditioned, fully worked, a bit smoky, etc, etc.
It will only collapse to a single state when you try to start it.
Old 21-07-2016, 09:50 PM   #18
superyob
Originally Posted by Crazy Dazz View Post
Not Quite.
So does this suggest parallel realities Crazy Dazz???
Old 21-07-2016, 10:32 PM   #19
wodahs
wodahs's Avatar
unstarted Clevo's exists in ALL possible states , rusted solid, and fully reconditioned, fully worked, a bit smoky, etc, etc.
sounds like some ones been in my shed recently I mean my mad scientist's laboratory (insert maniacal laugh here)
Old 22-07-2016, 09:47 AM   #20
mcflux
mcflux's Avatar
Schrodinger's taco cat palindrome?
Old 22-07-2016, 11:09 AM   #21
Cav
HUGH JARSE
Cav's Avatar
My mother warned me about taking drugs.
Didn't youse blokes listen to ya mother?
Cav is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2016, 11:26 AM   #22
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
I have nfi what's going on in here.
Back under my rock with me.
Cheers!
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2016, 07:37 PM   #23
Crazy Dazz
That's the Everitt Interpretation.
All jokes aside, perhaps the greatest irony of "Schrödinger's cat" is that if taken literally, a average lay-person's answer (that the Cat will in fact be either dead OR alive, long before you open the box) is in fact closer to the original Copenhagen Interpretation.
This is in part because Schrödinger emphasised the role of observation, but also because we weren't meant to think literally about a Cat.
Old 26-07-2016, 10:09 PM   #24
wodahs
wodahs's Avatar
so did we ever find the cat a home or we just completely loose it ? and any one given it a name yet ?
Old 27-07-2016, 07:58 AM   #25
cheap
Wirlankarra yanama
cheap's Avatar
Apply Bayesian probability to Schrödinger's cat - that will really do your head in.
No cats were harmed writing this post.
cheap is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2016, 01:24 PM   #26
superyob
Thank you very much cheap, now I have to look up Bayesian probability...
Now my head hurts again. So according to Bayesian probability, the test on the cat's condition is not the same as the actual cat and thus is flawed???
Old 27-07-2016, 02:01 PM   #27
wodahs
wodahs's Avatar
I didn't want to bring this in to the conversation as Bayesians Windsor Probability generally upsets a few
with his view that
Bayesians Windsor which can be justified by requirements of rationality and consistency , For subjectivists, probability corresponds to a 'personal belief' For subjectivists, rationality and coherence constrain the probabilities a subject may have, but allow for substantial variation within those constraints. The objective and subjective variants of Bayesians Windsor probability differ mainly in their interpretation and construction to the engines actual abilities
opps
and don't get me started on Bertrand's Big Block Paradox
Old 27-07-2016, 02:56 PM   #28
superyob
Bayesians Windsor???
Oh I get it. This is a Schrodinger's Cleveland thing...
Me are smart...
Old 27-07-2016, 11:23 PM   #29
malazn mafia
Boss 335
malazn mafia's Avatar
I'm no physicist but Schrödinger's cat story is absurd. Would probably be more interesting if it was called Schrodinger's Holden, where until Schrodinger turns the key there are two possible outcomes: the car is a ball-tearing 500 horsepower monster or the car can't start and is total piece of junk.
malazn mafia is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2016, 11:36 PM   #30
Crazy Dazz
Problem with that idea, is that nomatter the outcome, you're still stuck with a Holden.
