Old 20-05-2017, 10:03 AM   #1
FredNork
Default Anyone in Melbourne have an OBD2 Adapter for Ford BA I Can Borrow to Reset The Radio on My Wifes Car
I recently changed over the centre console on my wifes car as the display and controls were intermittently not working and now the radio comes up with CODE. It apparently needs a reset using something like Forscan, I am ordering an adapter but it will take up to 10 days. My wife is not happy as she has a long commute to work.
Anyone got one they are happy for me to use this w/e? Am in Melbourne, happy to leave deposit etc.
FredNork is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2017, 10:27 AM   #2
Interceptor
HSV - I just ate one!
Interceptor's Avatar
Default Re: Anyone in Melbourne have an OBD2 Adapter for Ford BA I Can Borrow to Reset The Radio on My Wifes Car
have you gotten the security unlock for FORSCAN?
I havent yet found any way to change any settings without getting the unlock....
I dont care if some prius driving eco-hippy thinks its politically incorrect for me to drive a V8..... I'm paying for the fuel!
Interceptor is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2017, 10:42 AM   #3
It would probably be quicker to drive to your nearest Ford dealer that has their Saturday service department open, pay a few dollars, and have it reset in a few minutes, than drive to a member's home to pick up an adaptor.
If you give them the VIN number they might even be able to look up the code.
Old 20-05-2017, 10:55 AM   #4
FredNork
I have only consulted the website and it says you can get a temporary unlock code on application
Old 20-05-2017, 11:23 AM   #5
pcman
if your near croydon north drop me a pm, have cables and software
pcman is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2017, 05:20 PM   #6
FredNork
Cheers mate,
have sent a pm
Old 20-05-2017, 06:31 PM   #7
Have you tried the following... Hold AM + Menu. That clears the code on the B series.
Old 20-05-2017, 07:07 PM   #8
FredNork
Hi thanks, yes this works, but only for 5 minutes. not a permanent fix.
Old 20-05-2017, 07:14 PM   #9
Not sure if this will work on the B series.... But on an FG series, if you change the ICC (which of course is mated to the car) with another replacement ICC, you can get around the coding problem by simply installing the CD player from the original ICC into the replacement ICC.
It appears the mating of an ICC to a car is coded into the CD electronics
Old 20-05-2017, 07:14 PM   #10
pundit
Gazza!
pundit's Avatar
Just register the program, it's free.. I've done it a few times and done coding stuff.
2005 Silhouette BA Fairlane Ghia Turbo
2017 AFF Nats best burnout chariot
ZF 6spd converted, GTX3582R, plazmaman and xforce goodies, tuned by BluePower Racing Developments.
11.79 @ 122mph
RIP 2006 - 2017
pundit is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2017, 07:20 PM   #11
Dalonian
Dalonian's Avatar
Slightly off topic, but will one of these allow you to re code ICCs, clusters etc
Vixen Red FG MkII Ford Falcon XR6 EcoLPI
My Show and Shine thread:
https://fordforums.com.au/showthread...27#post5975027
Dalonian is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2017, 07:20 PM   #12
FredNork
you are probably right,
Old 20-05-2017, 07:22 PM   #13
FredNork
you are probably right, however the issue is somewhere in the cd assembly which also includes the plug which is at the back of the icc, to remove the plug assembly from the cd mech is possible but would prefer to avoid if I can just recode,
Old 20-05-2017, 07:46 PM   #14
FredNork
Check out the Forscan site, lots of info there, but looks like it
Old 21-05-2017, 10:07 AM   #15
foxtrot3
foxtrot3's Avatar
Hi. The fault in your old unit may be repairable, have a look at this thread, https://www.fordforums.com.au/showthread.php?t=11462915 . The symptoms are different but the reason for the fault may be much the same, just a different pin (or pins). Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2017, 12:28 PM   #16
FredNork
Hi Michael, thanks for that, yes, I did do that to the old unit but must have missed the problem or its somewhere else.
Old 22-05-2017, 08:09 PM   #17
FredNork
still looking
Old 28-05-2017, 06:32 PM   #18
KRL-94
pm sent pundit
'99 AU Falcon S1 GLI factory manual in sparkling burgandy, 333xxx, NA + T BF barra conversion, FG TR6060 6spd manual, 3.9 lsd. Currently at 10psi. Power figure unkown at this time.
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
http://www.fordforums.com.au/showthread.php?t=11447916
KRL-94 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2017, 05:03 PM   #19
FredNork
My unit has arrived so no longer required, bit strange the offers made did not respond to PM's
Old 09-06-2017, 08:19 AM   #20
FredNork
OK, have used the forscan tool and reset the radio code successfully. Looks like you can do keys, change radio units etc.
Old 09-06-2017, 12:28 PM   #21
Fed
Fred which adapter did you buy, I have 2 here & both work with torque but refuse to work with forscan.
Hoping 3rd time's the charm.
Fed is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2017, 01:03 PM   #22
FredNork
http://www.ebay.com.au/itm/151533914...%3AMEBIDX%3AIT
This one worked for me
Old 09-06-2017, 01:35 PM   #23
Fed
Thanks Fred.
