Old 03-10-2017, 02:41 PM   #1
Tonz
Default little butons inside door
well they are Ford related, upgrading the wiring loom on FG and looks like I will need to replace those little white/cream buttons that hold the loom against the door panel......
any advice where to buy from please, or how are they released
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent
Tonz is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2017, 04:41 PM   #2
Default Re: little butons inside door
Check a fastener supply shop or the dealer.
Pop one out and take with you to show and compare that they have the right fastener.
Old 03-10-2017, 07:58 PM   #3
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Can you post a pic of the clip you are referring to..
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2017, 08:49 PM   #4
Tonz
the one with cable going through
Old 03-10-2017, 09:24 PM   #5
GTLEGEND
That is called a push type cable tie. Not sure if it is a separate part from Ford, but generic ones available like below which is a little different to genuine, but does the same job. Its basically a normal cable tie with a push in hole barb like a carpet or parcel tray plug.
http://www.ebay.com.au/itm/Push-Moun...h01mKR6Q4IXPVw
Old 03-10-2017, 09:26 PM   #6
Tonz
cheers mate....thats what Iam after
Old 03-10-2017, 09:39 PM   #7
GasoLane
Former BTIKD
GasoLane's Avatar
At $14 each I hope you don't want too many
Old 03-10-2017, 09:41 PM   #8
Tonz
yeah was just about to buy and hey what the ??? thank dog for search the same on ebay
Old 03-10-2017, 10:10 PM   #9
XC_Lizzard
As near as I can figure that $13.99 is for a pack of 100, as indicated when you select the drop down box for the length (155mm x 3.6mm x 100). Can anyone with more experience with e-bay confirm if this is the case?
XC_Lizzard is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2017, 10:13 PM   #10
XR6WGN
XR6WGN's Avatar
I also reckon that price is for 100 of them, have look at these ones:
http://www.ebay.com.au/itm/Titan-AV-...75.c100623.m-1
476 EF XR6 Wagons - 198 were Manual
2010 Anniversary XR50 in Sunburst - 6spd Manual
My Gallery Photos Here
XR6WGN is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2017, 08:34 AM   #11
Fed
You'd have to make sure they're the right size for the hole you're pushing them into.
Fed is offline   Reply With Quote Multi-Quote with this Post
