Old 06-11-2017, 09:50 AM   #1
LEEG
Default g6e radiator fan problem
When I turn on air con the radiator fans come on both full speed sounds like F1 11 aircraft . turn air con off fans run fine, codes say solar sensors out of range location and remedy. any help please GEOFF
LEEG is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2017, 02:47 PM   #2
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Default Re: g6e radiator fan problem
If you had an AC service lately, too much gas in the system will cause the fans to run at high speed all the time.
Just a possible cause..
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2017, 03:42 PM   #3
LEEG
Thanks for your suggestion but air con has not been touched ,this problem just started out of the blue regards Geoff
