Old 20-02-2019, 11:26 AM   #1
Default Direct Power to Door Locks
If you’re halfway through a job where the dash is out and you need to lock the car, this can help - it’s where you directly power the non-driver’s door(s) to lock or unlock. This is done through the large multiplug near the driver’s right ankle, behind the turned up carpet.
The wires are connected by miniature female spade terminals, to third pin from left, bottom and second-bottom row. To LOCK, apply +12V briefly to the upper wire and negative to the lower. Unlocking is the reverse. Just “blip” the wires, don’t hold them to your power source. Then key lock the driver’s door and you’re good.
Citroënbender is offline   Reply With Quote Multi-Quote with this Post
