Old 14-01-2023, 10:49 AM   #1
jackute23
jackute23's Avatar
Default 289w flex plate balance.
During recent work to my 289 Windsor where the engine was removed, evidently my flex plate got bent and needs replacing (C4 auto). What happens with the balancing of a new flex plate, are the already balanced when you buy them? Any advice greatly appreciated.
jackute23 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2023, 08:41 AM   #2
XRtowcar
Mustang GT mmmmmm......
XRtowcar's Avatar
Default Re: 289w flex plate balance.
Be careful when purchasing a flex plate that you match the one you have correctly.
Windsor have 157 and 164 teeth starter ring gear and also come in two different balance weights at 28 or 50 ounce.
Early ones are normally 157t 28 ounce, later roller cam engines 164t and 50oz.
Plenty of people have fitted the wrong flex plate and wonder why the engine has started to badly vibrate.
Eagle have a range of flex plates.
https://www.eagleautoparts.com.au/pa...20flex%20plate
I have become a Mustanger.
XRtowcar is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2023, 10:11 AM   #3
jackute23
jackute23's Avatar
Thanks very much, great advice, I'll get onto Eagle.🙂
Old 15-01-2023, 04:59 PM   #4
39ClevoUte
39ClevoUte's Avatar
If you examine your bent flexplate carefully you will soon be able to match yours. Count the teeth, look at the size of the counter weight and look at its position in relation to the crank bolt hole with the small cut out. Also measure diameter of the torque convertor bolt holes.
They all look different after a bit of practice you'll be good.
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2023, 05:04 PM   #5
39ClevoUte
39ClevoUte's Avatar
Here's a few to compare.....
https://www.custommustangs.com.au/au...89-302-c4-auto
https://www.ebay.com.au/p/1348752782
This one dosen't have a counter weight because the engine has been internally balance:
https://outlawspeed.com.au/shop/bm50246
