27-06-2005, 07:36 PM | #1 | ||
Interceptin'
Hey amigos,
I've noticed just recently that the EF is starting to idle a little rough. It almost feels it'll stall, but never does. She sits at the 600 rpm mark (if that's standard or not...) I'm wondering how i can go about tweaking something to get the idle much smoother? Cheers, Matt
'95 EF II Falcon, 'INTERCEPTOR' '72 XA Fairmont Coupe, 'XA Muscle' |
27-06-2005, 07:57 PM | #2 | ||
Clean the idle speed controller....
That might spruce up yer idle problem ! |
27-06-2005, 08:05 PM | #3 | ||
likes falcon's
headgasket!!!!!!!!!!!!!!!!!!!!!!!!!! :P
jk jk, there not like the old carbies. besides cleaning the isc wat else can u do?
www.carhubsales.com.au |
27-06-2005, 08:08 PM | #4 | ||
sssstttttiiicccccccckkkkky the last thread about idle quality.....
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
29-06-2005, 10:56 AM | #5 | ||
Interceptin'
Aright, where abouts is the Idle Speed Controller located?
It might need a good clean. thanks, Matt
29-06-2005, 11:19 AM | #6 | ||
It's the cylinder looking thing on top of the TB.
2003 Narooma Blue BA XR6 5spd Manual. Pacemaker 4490 Extractors 2.5" Exhaust High Flow Cat SS Inductions "Growler" CAI Underdrive Pulley Mal Wood H/D Clutch Custom Tune 18" XHP Sabre's 12" Kicker Sub 169.2 rwkw
13-07-2005, 10:36 AM | #7 | ||
Interceptin'
Im still not sure where the Idle speed controller is? The Max ellery's manual isnt much help for this (p123).
Any details on surrounding parts to help me find it? A picture would help heaps. Its a 6cyl. This problem I found started ever since I filled up with the new "Unleaded 95" unleaded fuel at Shell. It obviously doesnt like the higher octane level, and needs to be tuned to suit it. Cheers, Matt
13-07-2005, 11:16 AM | #8 | ||
No Speed Limits on Fwys
mine idles a little rough, and i run mine on 98 octane when i can get it, and there does not seem to be much differrence in the idle between normal unleaded and the 98 stuff, get better fuel economy though.
1996 EF 2 Fairmont
I like work, it fascinates me. I can sit and look at it for hours. : |
13-07-2005, 12:31 PM | #9 | |||
So to clean the ISC, remove it from the T/B and clean it out with turps, or T/B cleaner or something similar. Sorry I dont have a pic to help.
BA XR6 Turbo, Narooma Blue - Heinrich Tune, 19" BBS LM Replicas, 20% Tint Distant Past: '96 EFII Fairmont Ghia - Tickford Motor, Saloon car cam, 5sp, AU XR8 Snorkel, Extractors, 2.5" exhaust, Tickford Kit, Pedders suspension. Distant Past: '95 EF Fairmont - Cardinal Red, Auto, 17's King Lows, 115rwkw |
13-07-2005, 12:52 PM | #10 | ||
Former E-Series Member
The other thing to check would be engine mounts.
13-07-2005, 01:40 PM | #11 | ||
Custom User Title
13-07-2005, 02:24 PM | #12 | ||
Selekta, thats for an EA, this is for an EF. Its in a different place on the BBM T/B
13-07-2005, 02:39 PM | #13 | ||
Custom User Title:
Sorry if this is someone's car from here but I couldn't find one of my own on the net.
____________
Just sometimes, in between the first cigarette with coffee in the morning to that four hundredth glass of cornershop p**s at 3am, you do sometimes look at yourself and think... this is fantastic. I'm in heaven. |
13-07-2005, 02:43 PM | #14 | |||
Custom User Title
13-07-2005, 04:08 PM | #15 | ||
Interceptin'
Thats great thanks guys for the pics!
So is it the black cap that i remove? if so how?
13-07-2005, 04:10 PM | #16 | ||
No, you remove the whole unit. There are 2 10mm Sockets on either side. Undo them and when taking it off, be careful not to damage the Gasket. You will need to re-use it when you put it back on. When its off, just fill the guts of it with turps or t/b cleaner and shake outa it. Do this a few times
13-07-2005, 04:10 PM | #17 | ||
Oh yeah, disconnect the electrical connector to so you can take it away from engine bay. Makes it easier
13-07-2005, 04:28 PM | #18 | ||
Interceptin'
Great! Thanks for that hotwire.
I just grabbed a pick of what i was talking about :P but you beat me with a reply. I'll give it a good clean now. Hopefully it works out. thanks all, Matt
13-07-2005, 04:35 PM | #19 | ||
Custom User Title:
Good luck! Let us know if it worked or not.
____________
13-07-2005, 05:08 PM | #20 | ||
Interceptin'
Well that was easy to do, took hardly any time at all.
I'm yet to take it for a good run, but just starting her up, and sitting in her I noticed improvement. Im curious to what that black cap end does though, must alter something? Anyways I think she's purring a lot more smoothly now, thanks for the help champs!
13-07-2005, 05:21 PM | #21 | ||
Team Urinal Cake Racing
if its idling at 600 rpm turn the idle speed screw the falt blade screw in the pic u posted under the black knob clockwise about 1/8th to 1/4 of a turn itl increase the base idle
13-07-2005, 07:47 PM | #22 | ||
Could be idling low because of the dirty ISC, you should clean the ISC before you go playing with base idle.
13-07-2005, 07:51 PM | #23 | ||
Interceptin'
Yep cleaned the ISC this arvo, i'll give her a good run 2morro. If she still a little ruff I'll tweak the screw.
tah guys.
19-07-2005, 05:33 PM | #24 | ||
Interceptin'
Well giving the ISC a clean and tweaking the base idle screw to run a little higher, made small improvements, but my acceleration feels like its dying on me...like there's not enough fuel shooting into the chamber or something.
And braking quickly doesnt help either. It's a strange one used: : maybe ive had a bad batch of fuel???
23-07-2005, 05:11 PM | #25 | ||
Interceptin'
I actually thought Shell had changed ALL their normal Unleaded fuel to 'Unleaded 95' but i was wrong. So I've still been filling up with the norm. My boo-boo.
But I filled her up last night with with higher octane Un 95 and my idling seems to have improved quite a bit. And my dying acceleration has gone away. The higher octane level has helped heaps! ...but i still feel a small undercurrent of roughness lurking... Thankyou, more expensive fuel people yay :
24-07-2005, 10:44 AM | #26 | |||
own the road
sounds good matt. i sorta got the same issue as you without the dying accelaration so i'll have to give that a go.
T3 TE50 #146 Quote:
