19-07-2005, 08:29 PM | #1 | ||
Who knows why there's no S5 wire at pin 38 on my EB2 ECU...Need to find it to fit shift mod. resistors....Have got the 12v TCM wire at pin 57 tho...EB2 has the trans control module under the console too!!
19-07-2005, 08:33 PM | #2 | ||
Two > One
6cy or V8 mate?
19-07-2005, 08:34 PM | #3 | ||
Two > One
well sing the TCU is under the consol, you need to find the S5 wire on the TCU not on the ECU
You have a V8 obviously
19-07-2005, 08:38 PM | #4 | ||
V8's S5 wire is pin 7 (green) and +12V wire is pin 29 (yellow/red)
PS it took me forever to hook up the simplest of kits: single stage non-switchable! I dunno why it took me so long! Well worth it though ;) As for those who think I may be crazy for having it "on" all the time, it's only a very moderate setting, softer than the mechanicalforums.com circuit. -Dave- |
19-07-2005, 09:35 PM | #5 | ||
Tis an I6 fella's.....Who know's which wires under the console and do i use the same resistors as with the original mod.??? i've got a feeling this is gunna be tricky!!!
19-07-2005, 10:51 PM | #6 | ||
ahh sorry mate, don't know about the I6s :(
The circuit itself is simple. All you need is someone to say "that wire and that wire". Good luck! -Dave- |
20-07-2005, 10:19 AM | #7 | |||
20-07-2005, 10:36 AM | #8 | ||
Two > One
karl the EB 2 between 4.0l introduction and Smartlock, what went on with these cars?? May have the 6's still had a TCU?
20-07-2005, 10:46 AM | #9 | ||
Official AFF conservative
Agreed. If its trans controller, either a V8 (lol, maybe someone coverted to i6?) or early EB...
A cup half empty... but full of euphoria. |
20-07-2005, 02:03 PM | #10 | |||
20-07-2005, 07:02 PM | #11 | ||
I'm tellin ya's it's an EB2 cos i've got the original order sheet and manual with it...was delivered the 12/1992! The module i'm talking about is the one under the arm rest/storage box that you rest your arm on while drivin....It screws to a bracket on about a 45 deg angle under the p/wndws swicth ***. and i'm sure from memory it's got something about the trans on it....The only reason i'm asking about it is cos i read somewhere else that the eb2 had the seperate module.....And because there's no wire at pin 38 on the ECU connector!!! So now wot???
20-07-2005, 07:14 PM | #12 | ||
The thing your looking at is the cruise control ecu from memory. Your trans is definitly controled by the ecu which is on the passenger footwel under the cover. It might be possible that your looking at the plug the wrong way. On the ecu theres small numbers prinited on the plug itself, one side has 1, 21 and 41, the other side 20, 40, 60. follow those and you shouldnt have any trouble working out which pin you need. There is definitly an s5 solinoid wire there.
20-07-2005, 07:16 PM | #13 | ||
Also, you are partially correct when you say that EB2's have a trans controller. It is only in the V8's.
20-07-2005, 07:52 PM | #14 | ||
Doh!.....Found info on Ford mods and realised i waws counting the pins in the middle backwards which i sure would'nt be the first time that's happenned.....
Anyway i've fitted the resi's and it works great, should have done it ages ago! Was wonderin if a 25 ohm resi instead of the 22 would just take out that hint of harshness??? Thanks for info fella's..... :sm_headba Last edited by GASWAGON; 20-07-2005 at 09:03 PM. |
