Old 29-07-2005, 11:44 AM   #1
efgoofy
No Speed Limits on Fwys
efgoofy's Avatar
Angry Coolant Loss
Have been needing to fill the coolant reservoir quite a fair bit, have check for leaks there are noen, and there is no water evident in the oil.
Have had it check for a blown head gasket and it is not the case.
Its a ef 2 fairmont.
Any ideas?
1996 EF 2 Fairmont
  • 4.0 I6
  • 2 1/2 Inch Lukey Sports Exhaust
  • Custom Twin Tip
  • EL GT Snorkel, K&N Flat Panel Filter
  • Kenwood CD
  • 6*9 Kenwood rears
I like work, it fascinates me. I can sit and look at it for hours.
efgoofy is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2005, 02:36 PM   #2
ilsautomotive
Former E-Series Member
A pressure test at a radiator specialist would be the first port of call. Could be your water pump, a hose or radiator leakage.
Old 29-07-2005, 09:15 PM   #3
5speedeb
now with 3.73 lsd
yeah sounds like a water pump
how often to u have to fill it up?
5speedeb is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2005, 11:26 PM   #4
efgoofy
efgoofy's Avatar
Angry
twice in the last 3 weeks.
the first time wasnt really empty,
but the seond had the light on in the dash telling me it was empty.
how much would that be to fix.
1996 EF 2 Fairmont
  • 4.0 I6
  • Custom Twin Tip
  • Kenwood CD
  • 6*9 Kenwood rears
Old 31-07-2005, 02:25 AM   #5
jjj
jjj's Avatar
if your not seeing green coolant on your driveway inn the morning, then it's not a stuffed heater pipe. your head gasket is shot. $700 bucks to fix fix mate. can run it for 6 months if you want,should still kepp going if a slow leak..........
EL FAIRMONT
Pacemaker 4499's
Megaflow 2.5in Cat
X-Force 2.5in Sports Exhaust
Champion STEEL igntion leads
K&N panel filter, EL GT Snorkel, modified airbox
16in Speedy Holotype-R mags on 225 tyres
jjj is offline   Reply With Quote Multi-Quote with this Post
