10-11-2005, 04:16 PM | #1 | ||
Shoot.
Who's done it in an EA-EL I6? How hard is it? And how the hell do you get access to the top bolts on the bellhousing?
20V Turbo |
10-11-2005, 04:20 PM | #2 | ||
they call me Tibbo
use a long extension bar and a swivel adapter
10-11-2005, 04:22 PM | #3 | ||
She needs premium dude...
Its easy as. You undo the cross member and use a jack to slightly lower the back of the trans which will also tilt the engine back slightly. You should then have enough room to get to the top bellhousing bolts with a couple of long extenstion bars.
10-11-2005, 04:30 PM | #4 | ||
Shoot.
Cheers guys. Sounds easy enough. I just need some 1/2" extension bars now..
20V Turbo |
10-11-2005, 04:57 PM | #5 | ||
likes falcon's
supercheap sell big *** bars for around 10bux i think
www.carhubsales.com.au |
10-11-2005, 05:05 PM | #6 | ||
yes it is **** easy. :P I had like nearly a metre of extensions and a uni joined up when we did Dougs clutch, it was sik.
10-11-2005, 05:06 PM | #7 | ||
likes falcon's
ive heard of a story of one guy that dropped his kframe to get to the top ones...
thats pretty extreme stuff...
10-11-2005, 05:11 PM | #8 | ||
Windsor Man!
The extension bar option is the easiest, although, I have seen it done by lifting the back of the box, tilting the entire engine forward. You then use a spanner to get to the top bolts. Not too difficult, easier to get to them with an extension bar, wait, some extension bars, need a few.
Wife's car - BA XT Wagon - Lowm shiney wheels, dark tint, no bottom half of front bar, faded paint :/ My Car - 93 Diesel Lux - not as fast but more reliable than her falcon! |
10-11-2005, 08:53 PM | #9 | ||
Pics!
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
10-11-2005, 09:14 PM | #10 | ||
Yeah as said some long extension bars makes it really easy. Also it makes it very easy if you get the car up nice an high, the higher the easier to work with.
10-11-2005, 09:16 PM | #11 | ||
Sykmat
I had very little drama doing mine with with a spanner from the top of the engine you just have to get rid of all the air intake stuff.
10-11-2005, 09:26 PM | #12 | ||
BBQ gas User
Do you have any trouble getting enough torque onto the bolts?
1974 TC Cortina Sedan (sold); 1974 TC Cortina Wagon (sold); 1987 XF Fairmont Ghia (flooded); 1985 XF Ute 351 T5 (sold); 1995 EF Falcon (sold); 1999 Pajero & 2007 Aurion |
11-11-2005, 03:28 AM | #13 | |||
Shoot.
20V Turbo |
11-11-2005, 09:13 AM | #14 | ||
V8's are even easier :p
11-11-2005, 11:14 AM | #15 | ||
The first trans I did it was with a few extensions and a nice breaker bar.
I decided that sucked, so the other 10 trans swaps I did I bought a compressor and rattle gun. Makes the job so much easier. And by dropping the rear engine mount is enough to get to all the bolts. And its easier on earlier models as they dont have that thick heat/sound mat of the firewall that the EF/EL's get. |
11-11-2005, 11:34 AM | #16 | ||
Last warning
GLi's dont get that matting :P
so i'm fine!
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
11-11-2005, 02:58 PM | #17 | ||
I found it bloody hard to remove the t5 from my EA Ghia as one pice, all the sound deadner was in the way.
Much Much easier to take the gearbox off the bellhousing, and then undo the bellhousing. ended up being much quicker for me. |
11-11-2005, 04:31 PM | #18 | |||
need more boost
'94 ED Falcon GLi Suspended by: kings, koni, pedders Rolls on: 17" AJR Director's Stops due to: bendix, DBA Shifter connected to: T5 manual Power from: ??? Interior: velour and woodgrain Cost: stuff all :P |
11-11-2005, 04:57 PM | #19 | ||
Shoot.
I just bought a 600mm 1/2" extension bar, so hopefully that helps. I will probably buy another one if it doesn't!!
20V Turbo |
