Old 03-01-2006, 07:11 PM   #1
chich
chich's Avatar
Default 3.45 Diff Centre Swap & Speedo
Hi Guys,
I have been thinking of changing my EF Fairmonts diff centre to the 3.45:1 LSD unit used in the EF/EL XR range however reading through some posts has left me a little confused. Changing to 3.45s will increase my speedo error (its already a little inaccurate as a result of my 17s) however the auto will shift properly. Changing the speedo gear to the corresponding 3:45 gear will apparently stuff the shift points and you run the risk of revving the thing into redline on upshifts. Whats the go ??
Cheers,
Anthony
chich is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2006, 07:18 PM   #2
NC_Steve
She needs premium dude...
NC_Steve's Avatar
At full throttle the ECU uses only the speedo signal to change gears, hence why changing the VSS gear also changes the shift points at full throttle. You can fix this by correcting the speedometer signal only.
NC_Steve is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2006, 07:58 PM   #3
OED666
OED666's Avatar
Your speedo wont be out much at all with 17" wheels... It would only be out if you kept the same profile tyre as you had on your 15's.
I went from 14's to 17's and there was like 2mm Overall Diameter difference... Made no difference to speedo read out.
Ages ago, i found out my OD with 14" and 17" wheels from the bridgestone catalogue. thats how i found out there was only 2mm difference...
I know people who have put the correct speedo teeth on the speedo transducer in the gearbox, and its makes the speedo read correctly. You shouldnt have any problems at all...
If you get the diff gears, and corresponding speedo transducer cogs you will be fine...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2006, 11:18 PM   #4
chich
chich's Avatar
Okay, so what you guys are saying is that with the corresponding 3.45:1 speedo gear it will indicate the correct speed and shift as its supposed to - correct?
Old 04-01-2006, 07:22 PM   #5
OED666
OED666's Avatar
Yea, i think you will be fine with the correct speedo gear...
Turbo Barra ED 4L
Old 04-01-2006, 07:30 PM   #6
EF_Frmnt
EF_Frmnt's Avatar
The ECU shifts according to throttle position and RPM... changing the transducer gear (speedo gear) will not affect the shift points at all. Go into your local friendly for dealer an you should get one for under 10 bucks its just a little piece of plastic.. ask for one out of an XR.
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
