Old 11-01-2006, 10:37 PM   #1
riverrat321
Default EA 3 speed auto into eb-el series.
Hey guys im just curious if you could fit an old ea series auto into an eb-el series??? I'm told the older auto is more durable but i'm looking for a later model car. I' thinking I could buy an EL and if the box died replace it with the EA 3 speed auto?
riverrat321 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 11:31 PM   #2
16wantsI6
iRegular crossmember
16wantsI6's Avatar
y would u bother???
1996 EF XR6
5 spd manual
2 1/2" manta S/S exhaust
After market alpine/soundstream stereo
18" tyhpoons
superlows waiting to go in....
spoilerless
16wantsI6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 11:38 PM   #3
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
They were more durable than the early EA 4sp's, by the EL they were stronger than the early ones & the bugs worked out. Have a drive of one and then try it with the shifter in 3 not D - you will see where the above post is coming from. Because of the overdrive they were able to run a shorter diff ratio, so you will be pulling more revs when crusing anywhere from 70km/h up
Old 12-01-2006, 12:53 AM   #4
Lukeyson
Right out sideways
Lukeyson's Avatar
pretty much you get an EBII (or on wards) with the p/e switch = better than EA 3 speed all round, and durability isnt really an issue i wouldnt think with around 200Hp in front of them, give or take depending whether EB or EL
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2006, 01:40 AM   #5
Josh_XC
Originally Posted by 16wantsI6
y would u bother???
Yeh agreed why would u even bother.
Josh_XC is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2006, 02:26 AM   #6
stockstandard
Thats what I love about this forum. Someone asks a question which is followed by a series of "why would you bother" replies (even though he stated in the first post why he want to). Why not take the extra 10 seconds it takes to explain why its not worth worrying about and make your post meaningful.:
Failure of the 4 speeds is almost always caused by abuse or neglect. Service it when it is supposed to be serviced and fit a trans cooler (if there is not one already) and it will keep your car going for a long time. Also keep in mind that the 3 speeds were put behind less powerful engines in lighter cars with diff ratios to suite.
Originally Posted by casper
Old 12-01-2006, 03:21 PM   #7
riverrat321
Thanks for the input. I'm just a little worried cos I had bad and expensive problems with my old vr commodore.
Old 12-01-2006, 03:53 PM   #8
Valknutr
Valknutr's Avatar
you just made a few friends in here lol
MORE AMMO FOR THE WAR!! 4:
car that goes (just) <----- gonna be MENACE so :thebirds:
Valknutr is offline   Reply With Quote Multi-Quote with this Post
