Old 15-01-2006, 03:20 AM   #1
BABOSS
BABOSS's Avatar
Default Power loss checklist
Hi All,
I was wondering if you could please help compile a list of things to check out when experiencing power loss or no gains after mods have been added. Where are the most 'common' places to start looking?
-Blown Head gasket, check oil cap, dipstik and exhaust for water.
-Blocked Cat converter, dismantle cat and inspect, replace if required.
-Blocked/dirty air filter, retrieve and clean (if non-disposable filter) or replace.
-Mods added; ECU needs a reset to re-learn new mods, disconnect battery ground for 1/2 an hour, then reconnect.
-Cracked head
-Old Spark plugs and/or leads, replace.
-Blocked Fuel injectors
Thanks.
BABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 09:38 AM   #2
AshMan
Girrrrr!!!
AshMan's Avatar
Fuel filter and fuel pump pressure and flow rates.
Clogged injectors.
No fuel in tank.
Check vaccuum lines.
AshMan is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 10:04 AM   #3
ilsautomotive
Former E-Series Member
- strecthed throttle cable
- timing out
