Old 27-01-2006, 12:50 PM   #1
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
Default quick question about removing rocker cover
does an ED rocker cover need to be removed with a torque wrench?
cheers
BA MK2 XR6T
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 12:59 PM   #2
Psycho Chicken
Psycho Chicken's Avatar
You don't need a torque wrench to remove anything. If you're going by the book you need one to put it back on, but if you know what you're doing you don't.
Old 28-01-2006, 04:11 PM   #3
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
i'm just interested in giving it a new coat of paint and would like to remove it and do a good job.
however i've been told that it has to be taken off and put back on with a torque wrench so that the head isnt damaged.
BA MK2 XR6T
Old 28-01-2006, 04:26 PM   #4
NEG
Diabolus
NEG's Avatar
torque wrenches are only made for tightening bolts not undoing them. just use a spanned and be careful not to squash the new gasket to much when tightening it back up, they dont need to be super tight.
NEG is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 04:27 PM   #5
Hardtopxb
Once PHASED.
Mate, a torque wrench is for tightening(doing up),you do not need a torque wrench to UNdo(loosen)......
2006 BF XR8 Bionic.
Hardtopxb is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 07:19 PM   #6
RepSpec
Formerly XG-Panelvanman
make sure when u put it bak on the gasket on the rocker cover doesnt come off or move when u put it on
this will result in an oil leak which i have at the moment
My Ride:
BA MK2 Wagon, dedicated LPG, white.
modifications:
cargo barriers, tow bar
RepSpec is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 09:56 AM   #7
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
is it possible to damage anything by taking it off and putting it back on?
BA MK2 XR6T
Old 29-01-2006, 10:15 AM   #8
naughtyfalcon
ummm no,except
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 10:19 AM   #9
Racecraft
they call me Tibbo
Racecraft's Avatar
just number your leads 1-6 if you don't have the prestamped ones and don't overtighten it when you put it back on.. At worst it'll leak alittle if you under tighten the bolts/nuts or crack the rocker cover if you over tighten it, but either way you couldn't possibly damage the head itself
Old 29-01-2006, 06:34 PM   #10
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
thanks racecraft
time for painting! :sm_headba
BA MK2 XR6T
Old 29-01-2006, 07:16 PM   #11
GenesiS
*Smart *** comment here*
GenesiS's Avatar
dont forget to fully clean it, else all those bits of burnt gasket on the head will cause oil leaks... use a razor and some 2000 wet and dry, bought the el up like it was chrome... no leaks so far!
1997 4.0L EL Falcon GLi Sedan Auto
2.5" Cat Back Mandrel Bent Exhaust to Two Lukey Sports Mufflers and a 3.5" Dump Pipe
Lowered all round on King Spring Super Lows
Tinted Windows, Pioneer MP3 Player and Audio System
K&N High Flow Air Filter Mounted in Original Air Box
Trip Computer
NGK Sports Performance Leads
NGK Sports Plugs
Autotecnica Oil Catch Can
GenesiS is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 07:47 PM   #12
Age182
GMHKLA number plates
Age182's Avatar
u should never undo with a torque wrench they stuff up like that
Currently owned: 1997 Hyundai Excel (the daily)
2009 FG FPV F6 Silhouette Auto
Previously owned:
1994 EF fairmont Ghia 4.0Ltr, AUTO
14.620@93.3mph
2000 Honda S2000
14.73@92mph (stock + no traction)
Age182 is offline   Reply With Quote Multi-Quote with this Post
