Old 28-01-2006, 06:30 PM   #1
Grechie
Grechie's Avatar
Default Compression Lockup @ 100km/h
aii guys
scariest ИИИИin thing happen to me last nite, the scene is princess freeway, about 1:30am, near millers rd turn off, i go to gear down to 3rd from 5th, at 100 km/h, the basterd goes into 1st,(mind u that 5700rpm is 1st gears rev limiter at 60km/h) BANG compression lock, car kicks out sideways on the highway , correct it, hits the limter, motor screams off its tits, then motor turned off...n a mate next to me seen sparks thrown from underneith...
pulled over, another mate came back, from down the highway, said they even heard it like 15 car lengths cruising infront of me @ 100km/h, checked to see if there was ne holes in the block ,there woz none, tried turning motor over, starter motor made the most ИИИИed noise screachin n wot not, and the motor finally turns over n pretty much idles friggin lumpy, like on 4 pots, like 2 pistons were blown, limp her home, n car wont start no more, i thought it was seized...i could nearly cry, because it was over something real careless...
today, we got straight on it, 9am, we seen that the starter motor was unbolted n just hanging there!, n the map sensor hose was blown straight off, after fixing all that, motor started! OMFG!!!!!!
checked all leads, all pistons were firing, all gave a miss to the back wen a lead was taken off...took it for a drive, 2nd gear missed once then cleared up, n she drives fine, what a freakin friday night scare...., no cruising tonite for me, ill tag along if anyone cruises from here...id say, give her a rest, n a pat on the back, for surviving....
Ford, Built Tough
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 06:36 PM   #2
gthofan
Gunna girlie-man
gthofan's Avatar
jees grechie, it would have scared the livin hell out of u. hopefully there is no gearbox, diff or engine damage done
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 06:41 PM   #3
Grechie
Grechie's Avatar
thanks man, so far, car drives fine, gears go in fine, no engine noises, and , well i guess, no weird sounds comin from back there at the wheels...lets hope, it keeps its performance, i think, from soomethign like that, that it would make the engine slower?
KPM Street Fighter
PCMTec
Old 28-01-2006, 06:53 PM   #4
clontarf_x
I wanna know how the hell you managed to select 1st! good to hear shes still running, that coulda done some major damage to you and the car!
clontarf_x is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 07:21 PM   #5
RepSpec
Formerly XG-Panelvanman
very lucky to come out of it with no damage
my mate used to do that in his corona on purpose but dont do it in a ford
My Ride:
BA MK2 Wagon, dedicated LPG, white.
modifications:
cargo barriers, tow bar
RepSpec is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 07:29 PM   #6
94EDxr6
5.SPEED
94EDxr6's Avatar
damn... what oil do you run? I've only ever heard such horror stories at the wreckers - very lucky
94EDxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 07:29 PM   #7
Grechie
Grechie's Avatar
penrite HPR15
KPM Street Fighter
PCMTec
Old 28-01-2006, 08:56 PM   #8
eav8
eav8's Avatar
you may have been lucky enough to have had your clutch slip a bit and save your driveline from the harshest of it...But by god you were lucky...I would be changing engine, gearbox and diff fluids just to make sure there are no little bits floating..Just for a bit of piece of mind.
project #1: Ea series1 Spac conversion to straight gas; 351Cleveland; T5; EB dash; sunroof and more as I get to them. :evilsasmo
Fully road legal and cruising in QLD!!
Happy dealings with; PROTD, !gn!t!on, Big_waity,Phongus
eav8 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 09:13 PM   #9
MADED-6
MADED.6
MADED-6's Avatar
thats hardcore u inspire me to see if mine survives. nah just kidding thats a strong motor u run if only u had a 10,000 rpm tacho so u could have seen wat revs it was hitting.
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 09:32 PM   #10
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
glad to hear it came out ok.. But what i dont get is how the selector allowed it to go into 1st??? Every manual ive driven you have to absolutely jam the thing into first higher than its set level??? coul be different with yours??
Just in interest, what would have happened??? i assume since the motor was being driven by the turning wheels, it would have spun the motor to about 8700rpm???
Just curious?
Cars:
- Ford Ranger Wildtrak
- XY GT Replica
- XB Coupe Project
BOOSTDEF is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 09:36 PM   #11
gthofan
Gunna girlie-man
gthofan's Avatar
somebody was driving my car a while ago, i was in the passenger seat and my mate driving couldnt drive a manual too well. he went from 4th to first at 70kmph. the revs skyrocketed to 5500rpms, i pulled it out of gear so fast, but at 100kmph god damn, id say at least 7500rpm
Old 28-01-2006, 09:36 PM   #12
EDXR6T
see this is wut happens wen u skip gears on down shift hope we learnt a valuble lesson :
good to hear ur allright mate yer might pay to drain the fludes just to see if thers n e bits floting around
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 10:21 PM   #13
niko
likes falcon's
niko's Avatar
dude u gotta force it to get into 1st, is your box an x-stkilda job or something? :P
www.carhubsales.com.au
Old 28-01-2006, 11:55 PM   #14
neb
hibernating
neb's Avatar
It probably wouldn't of gone above 6000rpm... It would of hit the rev limiter? Or does your car not have one? Anyway as you said the car went into a compression lock meaning the wheels were turning slower than the actual road speed, plus the clutch most likely would of slipped a bit as well. Those 2 things probably saved your engine from death.
Yeah I don't know how you could manage to change into 1st gear !!
neb is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 11:56 PM   #15
Grechie
Grechie's Avatar
it went into 1st fine, and yeah it hit the rev limiter, lol weird, ill changed the fluids i guess to see if theres ne thing in it
KPM Street Fighter
PCMTec
Old 29-01-2006, 12:06 AM   #16
XR Martin
XR Martin's Avatar
Rev limiter wont stop the car hitting high rpm if its a miss-shift, since its doing it mechanically, and nothing will stop that.
You're lucky you didnt smash the valves or explode the flywheel.
2004 BA wagon RTV project.
Old 29-01-2006, 12:50 AM   #17
Grechie
Grechie's Avatar
true that man, well the motor shut off and stalled, yes thats right, no software could stop the pistons from doing 7,500rpm for a split second, i swear,, so far theres no unusual noises, n she drives fine, id like to run some checks, maybe another run to see if i can get a similar result, see if it ИИИИed it, the starter motor grinded agaisnt the flywheel apprently, n created the spark, have to as i sed run some tests n a better check, but the quick check underneith n on top shes fine...lets see how the next few days go
KPM Street Fighter
PCMTec
Old 29-01-2006, 05:26 PM   #18
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
your lucky!
Ive just one question, why would you shift from 5th back to tird at 100k?
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 06:55 PM   #19
Grechie
Grechie's Avatar
i was entering a exit, instead of going 5th to 4th to gear down, i wanted to gear down straight to 3rd to slow my self down without any brakes n it popped into 1st:( ИИИИing thing, never again tho, just put it in Nuetral and brake or go to 4th firstly
KPM Street Fighter
PCMTec
Old 29-01-2006, 07:10 PM   #20
Damo
maybe the bush on ya shifter is flogged, does the shifter spring back to the centre ? I would have thaght it would be very hard to accidently go 5th to first. Oh well you learnt a lesson and came away from it with a car still intact.
Old 29-01-2006, 08:48 PM   #21
mcflux
mcflux's Avatar
Theoretically you would've been doing 8060rpm...
2500@100 (assuming gearing of 1:1 and 2.77 diff... this is what I used as a start point)
Change diff ratio 2.77 --> 3.27 --> Gives 2950rpm
Change gearing of 1:1 to 0.78:1 --> Gives 2300rpm
Change gearing of 0.78:1 to 3.5:1 (this is EA 1st?) --> Gives 8060rpm
Methinks the clutch would've slipped somewhat or your engine would've let go in a big way!
Autos rock :P
-Dave-
Old 29-01-2006, 10:12 PM   #22
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
Why didn't you just put your foot back on the clutch and go, oops, don't do that again.
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2006, 02:33 AM   #23
Grechie
Grechie's Avatar
i did, after the engine stalled pretty much instantly
KPM Street Fighter
PCMTec
